Thread: Removal of Wiper Motor and linkages
    Well, I though removing all of the fasteners would be enough to get this out but there appears to be more to this then I thought.
    Can anyone give me the hint required to maneuver this out from underneath the dash? Do I have to separate the motor from the linkage?
    Any help would be much appreciated.
    Regards,
    Bob
    1970 911S Targa
    On the road again soon.
    There is a strap which is bolted to the wiper motor and also to the metal under the dash that holds the wiper motor in place. You will have to seperate it in the middle or remove the dash to get at the top of it!!! Its a pain.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    I'm sure you've already done it...but if not...be sure to disconnect your batteries before trying to get the wiper motor and linkage mechanisms out. If it inadvertantly cycles on while your hand is up in there it's very powerful and can do serious damage to you. Good luck with this pain-in-the-rear task.
    Thanks for the tips guys.
    I was able to get it out by undoing the motor fasteners and swinging it out of the way. Then the motor and the linkages could be lowered enough to remove it all from the car. I am not to sure if I will be able to install it in the reverse order so maybe I will figure out how the factory did it. I there must be a better way.
    Good tip with the battery Richard. I am sure you could really hurt yourself if the motor were to actuate with your fingers in there.
    Best regards,
    Bob
    1970 911S Targa
  1. Fs rhd window wiper motor and mech? With wiper blades
    By advtracing in forum For Sale: 911 Parts
    Last Post: 09-27-2012, 12:48 PM
  2. Wiper & Light switch mount removal
    By SteveG in forum Technical Info
    Last Post: 12-22-2010, 12:34 AM
  3. Wiper motor replacment w/ 944 motor
    By super9064 in forum Technical Info
    Last Post: 07-26-2008, 03:34 PM
  4. Help needed- wiper linkage removal
    By mobius911 in forum Technical Info
    Last Post: 12-19-2007, 10:43 AM
  5. Wiper Motor Removal and Wiring Question
    By t6dpilot in forum Technical Info
    Last Post: 01-15-2007, 09:46 AM
