Results 1 to 10 of 17
Thread: ID Plate Rivets
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    ID Plate Rivets
    Unfortunately, I have to drill out the rivets securing my ID plate to the A pillar in order to remove the vinyl in order to repair some rust at the base of the A pillar ('70E). How can I replace the rivets without having it look like monkey business has been had with the car? Please PM if you think that this kind of information should remain less public.
    -Scott
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    Apr 2003
    Portland, OR
    Somewhere on Pelican I think there was a long thread on the subject. What you need was found at McMaster-Carr. I would give you a reference but I cannot access Pelican from where I am right now.
    Harry
    Member #789
    2009 MB C300
    Dallas, TX
    I had to drill mine out to replace the windshield frame vinyl trim.
    Apparently some idiot, who will remain nameless, sliced it up nicely while cutting out the windshield rubber. It needed replacing anyway after getting some paint on it during "rustoration". Does anybody have any tips on replacing the vinyl?
    Scott, if you buy some in bulk, can you send me a couple? I pay for half. I don't think that we both need 100 rivets each.
    Neil
    '73 911S targa
    May 2003
    Eugene, Oregon
    Thanks, Harry. I'll look at Pelican.
    Neil-
    Sounds like a deal. I'll let you know.
    ’15 VW GTI
    '70 911E, Sold
    Paint tag rivets
    International Mercantile, in Del Mar, CA has the small rivets for the A pilar paint tag. You can reach them at 1 800 356-0012
    Bob
    Apr 2003
    Portland, OR
    I finally found the posting at Pelican for the screws for the Paint code plate. They are listed at McMaster-Carr (www.mcmaster.com) as "Drive Screws" (see page 3137). They look like this:
    I am not sure what is needed for the A pillar VIN code rivets.
    Harry
    Member #789
    2009 MB C300
    Dec 2004
    SE Michigan
    I'll buy some from you also since I am doing the same thing.
    You can email me at twopointsevenrsAThotmailDOTcom
    May 2003
    Eugene, Oregon
    Upon further inspection, it is clear that the color code plate and
    ID plate don't use the same fasteners. The ID plate is fastened with larger diameter rivets that have a hole in the center. The drive screws would certainly work, but not be completely correct. I'm talking wiht International Merchantile about this. I'll let you all know what I find.
    Thanks for all of yor help.
    -Scott
    ’15 VW GTI
    '70 911E, Sold
    Mar 2004
    Twin cities minnesota
    Paint code/ ID plate rivets
    The rivets you saw with the hole in the middle are either pop rivets or CherryMax blind fasteners. I do not believe the factory used either of the fasteners when they built the cars.
    May 2003
    Eugene, Oregon
    kstens-
    Are the "drive screws" cited above the correct fastener for both the color plate and the ID plate? I would be really surprised if mine were not original, but I guess anything's possible.
    ’15 VW GTI
    '70 911E, Sold
  1. Rivets for threaded plate for plastic tank hold down
    By billm in forum Technical Info
    Last Post: 05-24-2012, 07:04 AM
  2. WTB: Vin Plate Rivets
    By prez! in forum For Sale: 911 Parts
    Last Post: 05-19-2011, 05:33 AM
  3. Pop Rivets for ID plate in trunk
    By WM711 in forum Technical Info
    Last Post: 05-21-2009, 03:35 PM
  4. 1972 911S Door sill Plate Rivets
    By lotus15racer in forum Technical Info
    Last Post: 03-10-2006, 05:54 AM
  5. VIN plate Rivets
    By RandyWebb in forum General Info
    Last Post: 04-25-2005, 08:59 AM
