Thread: Need help ID'ing Koni struts
    Oct 2004
    Cambridge, MA
    I've picked up a few front struts recently, each described as 69-73 S Koni struts.
    But they are different and I need clarification before doing a front rebuild on my 69E which has S calipers.
    Set 1
    91134192601 It has a pin type base that attaches to the ball joint
    Set 2
    90134107910 The base is threaded for attaching to the ball joint.
    Any help in identifying these is very much appreciated! Even something like: S Koni struts didn't have threaded bases is very useful.
    thanks!
    Oct 2004
    Cambridge, MA
    piccccccccccccc
    Suffolk, VA
    I have a 1970 S, and I know the struts are original, so I will check the part number tonight. It seems to me that mine has a pin type base. I'd assume that that the 901 part number strut might be for a SWB S car.
    Citation F1000 on the way
    Other Early 911/912/914
    Oct 2004
    Cambridge, MA
    Thanks Rob, no need, I confirmed that the 901s were misrepresented as 69-73. Now I just have to get my money back.
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Neither of the struts pictured are for a SWB car...they are totally different. The 69-72 cars had a different ball joint than the 73-89 cars, although they are interchangeable. Both struts pictured look to fit a 69-89 car...I did look at my 73 Koni struts and they are not threaded. I do not have a 69-72 strut to compair, although I do have a few SWB? struts...A SWB koni has a removable brake caliper plate and has a removable spindle as well. They look very different than your pictures.
    Good luck.
    Michael
    72 911S Coupe, Sepia Brown
  1. Replies: 3
    Last Post: 03-26-2014, 03:41 AM
  2. Replies: 3
    Last Post: 09-15-2013, 11:13 AM
  3. FS: Koni Struts
    Last Post: 07-14-2013, 02:44 PM
  4. FS: '73 S Koni Struts
    By 913 in forum For Sale: 911 Parts
    Last Post: 04-23-2013, 05:06 PM
