Thread: How do you "loosen" seatbelts
    My 73E has inertial seatbelts, and they work just fine (even the inertial part of them) but they retract soooo hard, it feels like the car is trying to choke you when you put them on.
    How do I loosen the tension on the retractor so that they don't drag on us so hard. My wife has gotten to put the seat belt under her arm to protect her neck!!!!!!
    larry
    06 - Lexus IS250 MT6
    98 - Volvo 70V XC
    New retractors can be bought although the "B" pillar hardware on them is not exactly like your originals. I'd replace them to be on the safe side. They are not terribly expensive and if you do "get to use them", it's better to have something that is going to work vs. a "maybe going to work". Besides, you wife will break her arm the way she's wearing it.
    Tom
    Early S Registry #235
    rgruppe #111
    Senior Member sweetE's Avatar
    Dec 2002
    Highlands Ranch, CO
    Talking
    Larry,
    I use a cloths pin to hold against the top loop to ease the tension on my 912E. Maybe this will help you??
  1. FS: Special Extended Hub 380mm "RS" "RSR" Thick Grip Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 06-06-2014, 12:47 PM
  2. FS: Special Extended Hub 380mm Thick grip "RS" "RSR" steering wheel
    Last Post: 10-30-2013, 01:47 PM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-09-2012, 07:53 PM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
  5. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 01-24-2012, 01:59 PM
