Results 1 to 9 of 9
Thread: Rear Window Defog Option on a 67 911?
    Question Rear Window Defog Option on a 67 911?
    Guys,
    I bought a used rear window on EBay last month in order to replace the one on my 67 which has some stains in between the glass which I can't get to.
    When receiving the glass I noticed that it has the rear window defog wires. I am wondering if the 67 model year had this as an option or if it was only available for later models. I would be reluctant to use it if it were not an option for 67. Anyone?
    Eric, with all of your 67 911S's and knowledge of the SWB models, I would expect that you would know this off the top of your head....
    Apr 2004
    It was an option in 67
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    Suffolk, VA
    Yes it was an option.
    Citation F1000 on the way
    Other Early 911/912/914
    It is controled by a push pull switch located between the steering colum and the cigerate lighter.
    My 67S sunroof ,has this option; My car was European ; returned to North America; Probably more prevalent in Europe than North America; Likewise, Rear window wiper;
    Aziz ; VARIOUS PORSHAS
    If you're going through the trouble of hooking up a switch (if there's none now)
    AND, if you want the defroster to be functional...
    Make sure to check the continuity of every wire in your new/used window...
    Before you go through the exorcize, find out if the window will
    work when hooked up...
    When replacing mine years ago... I went through 5 used rear windows before I found one that showed continuity through every one of the wires...
    Just my 2 cents...
    Cheers,
    Chuck...u really *NEED* a rear defroster in California???
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Only for those Cambria/Monterey long weekends Paul...
    Seattle WA
    Sorry, wasn't on earlier...but you have your reply...
    Accessory code for that item is 9484, and it could also be had with "tinted" (catacolor) glass.
    It was fairly expensive...$62.50, considering that a 100 litre tank was $74.50, and sport seats were only $15.00 (which is deceptive, as you had to give up your regular seats....).
    e
  1. Replies: 1
    Last Post: 03-20-2014, 05:24 PM
  2. FS: Rear Tow Hook, option M428
    By srogebry in forum For Sale: 911 Parts
    Last Post: 12-24-2013, 10:57 PM
  3. window sticker option codes
    By 72starga in forum Technical Info
    Last Post: 08-03-2009, 05:23 PM
  4. ducktail with rear wiper option
    By rennmeister in forum Technical Info
    Last Post: 09-08-2006, 06:50 AM
  5. WTB:69 Rear seat delete option
    By Ivs in forum For Sale: 911 Parts
    Last Post: 11-30-2005, 11:34 AM
