Thread: Throttle Body Torque Specs
    I'm going to clean the throttle bodies and replace some gaskets on my '73 next weekend. Is there a recommended torque spec for installing the throttle bodies to the heads or the velocity stacks to the t-bodies? I can't find any in CMA or in my spec book.
    Quote Originally Posted by jayzoll
    Jay:
    10-12 lbs-ft is plenty for the throttle body-to-head flanges. You don't want to distort the magnesium. The stacks are tightened to, "just snug". Use new gaskets, of course.
    Use a short-handled 1/4" drive or 3/8" drive handle so you don't overtighten these things; its a finesse thing.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Thanks, Steve.
    That's about what I expected, I just wanted to make sure--I certainly don't want to crack my plactic stacks.
    Nossir, you surely don't,....
    Remember,......."Less is more".
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    You may want to put the bottoms of your TB's onto a flat surface to make sure that they are flat. The flanges may be pulled downward a touch and needed to be skimmed. The distortion could be from previous over- torquing of the nuts or material creep over the years. Either way if they are not flat you can get a bad seal.
    1970 911S Targa
    On the road again soon.
  1. '67S Brake Bleed Screw Torque Specs?
    By Bob Schaefer in forum Technical Info
    Last Post: 06-09-2008, 10:09 AM
  2. Torque Specs
    By 356robo in forum Technical Info
    Last Post: 03-30-2007, 09:56 AM
  3. aluminum lug nut torque specs
    By NiceT in forum Technical Info
    Last Post: 04-27-2005, 02:54 AM
  4. Steel Lug Torque Specs.
    By BradAndersonPHOTOWERKS in forum Technical Info
    Last Post: 01-10-2002, 09:23 AM
