Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: '68 911L/S Brakes
    More than Original
    Jun 2004
    SoCal
    Question '68 911L/S Brakes
    I have a 911L same brakes as a 68 S and I am planning on replacing the lines, pads and rotors, inspecting the calipers, and of course doing a flush. My question is what parts should I go with? Is the OEM rubber lines just fine or should I go with a SS wrapped lines? What type/brand of rotors should I get, I have seen slotted drilled rotors for the front but I also heard they are more prone to cracking? And finally what brand of pads? The car is a weekend driver that is taken for spirited drives at times and I plan to auto-x about 6 times a year. Any links, examples, suppliers, recommendations would be appreciated.
    Bob what are you running or what would you like to be running on your car?
    Bret Davis
    1968 911L
    I understand that the 67/68 vented rear rotors are no longer available, but 944 rear rotors can be machined down to fit.
    I would fit SS braided lines throughout
    Seattle WA
    Nick,
    Does that mean that the front rotors are still available? I knew about the rear issues....
    Eric
    i am running SS lines on rebuilt stock braking system. it was one of the first things i did when i purchased the car so i didn't know too much then...and still don't .
    i would pursue nick's idea otherwise swop out your whole front end for later susp set-up and 3.5" braking. i already rebuilt my entire susp...again when i didn't know too much.
    actually i didn't want to chase my tail in upgrades...first this then that then more of this...$$$.
    btw B D, i really like how your car is coming along.
    nick - when you gonna unveil the blue 68S?
    eric - good to meet you in monterey FINALLY!
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    I fitted new front rotors, they are common from the 68S up to the SC!
    The 68S went off to its new owner this morning, I was sad to see it go
    Loads of pics here
    just looked the the entire 68S resto pages - AWESOME JOB NICK! that is going to be one happy owner. i like the autofarm exhaust. i noticed the facet fuel pump in the engine bay. these units are good - yeah? i may need to replace my orig pump and was leaning towards a facet for my carb'd 2.7.
    _B
    www.werkcrew.com
    The Facet pump was already on the car. Its a bit noisy before the motor is started but it sure pumps loads of fuel
    More than Original
    Jun 2004
    SoCal
    Quote Originally Posted by nick-moss
    What exactly is the process for machining down the 944 rotors, how much and who does this. I don't want to swap in many newer parts, I want a period hot rod and want to keep the price down. Could non-vented rotors fit, I don't think I would go this route. I should go pop a rear wheel and check out what is back there now, who knows?
    Soterik the fronts are still available.
    Bob I would go with a Pierberg pump, it's the pump PMO recommends and sells. It's self regulated at 3.5 lbs ideal for carbs, I just ran it in to a Morso splitter with a psi gauge. It's much quieter than the faccet, but gives a nice single click when it gets power so you know it's working. You can get it from PMO or Pelican for around $80.
    Bret Davis
    1968 911L
    If you change to non vented rotors you will need to take the spacers out of the middle of the calipers. Do a search on this site for "944 rotor" and you will find quite a bit of info on 68 brakes.
    Jul 2003
    Santa Cruz, CA
    my 70S had those same Cibie fogs on it. Funky!
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  1. Replies: 43
    Last Post: 01-16-2014, 03:10 PM
  2. Replies: 11
    Last Post: 12-10-2012, 02:58 PM
  3. Brakes on a '70 3.8RS
    By amsterdamned in forum General Info
    Last Post: 10-19-2008, 05:40 PM
  4. S brakes or not
    By rac4bux in forum General Info
    Last Post: 11-05-2006, 01:08 PM
  5. 1968 911L Brakes-Conversion?
    By jl2002 in forum Technical Info
    Last Post: 02-28-2005, 07:17 AM
