Results 1 to 2 of 2
Thread: MFI Air Bleed Screw Sizes
    Suffolk, VA
    I have seven throttle bodies, trying to make two. Unfortunately, the two I castings I want to use have smaller diameter orifices / threads than the 1972 version of the air bleed screws. Anybody know what the differences are by year? I thought I had 4 1970 versions, but 2 of them have the larger orifices and 2 have the smaller version. I'm wondering if the smaller orifice version is from 1969. The 1972/1973 version is quite different wrt throttle plates, and that has the larger orifices.
    Citation F1000 on the way
    Other Early 911/912/914
    Suffolk, VA
    I already drilled out the passages to the larger size and re-tapped the air bleed screw threads.
  1. 67s screw or no screw - an interior question
    By joshkras in forum General Info
    Last Post: 02-10-2013, 02:53 PM
  2. Fan Sizes
    Last Post: 06-18-2010, 07:04 AM
  3. Brake rebuild/bleed system problem
    By Allen Henderson in forum Technical Info
    Last Post: 11-10-2008, 07:13 PM
  4. '67S Brake Bleed Screw Torque Specs?
    By Bob Schaefer in forum Technical Info
    Last Post: 06-09-2008, 10:09 AM
  5. Air bleed screws
    By 72narrow in forum Technical Info
    Last Post: 10-10-2001, 03:57 AM
