Results 1 to 7 of 7
Thread: what should compression readings be 69 911s?
    Apr 2004
    35,000 ft
    looking at a '69 911 S, 2.0 orig motor, car has all documentation since 1974, and no rebuilds, compression is within 5% of each other, but seems consistently low, it is possible low compression pistons were installed before 1974...compression readings 4-5 years ago gave the same results as today....so, what numbers should I look for???
    -Lewis
    My '69 911S just had a compression/leakdown on its PPI. Motor is relatively fresh and we got ~125 psi w/ 6% - 7% leak down across all cylinders.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    compression readings can be low on high compression, high performance engines because of valve timing overlap.
    Check leak down too, and if all cylinders are good, there is probably not a problem..
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
    Hey Lewis
    I recently had my '69 S engine rebuilt. After some mileage the compression values came out to 162-165 psi and the leak down values were 2-2.5%. This is according to my mechanic who did the rebuild. Everything was to original spec. Does this sound about right to the experts?
    A.T.
    I would have never imagine you could psi readings that high on an 'S' cam. I know my motor is about 15K miles old and I was getting the numbers quoted above.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Kenikh,
    My numbers were in Canadian psi so if you figure with the exchange your numbers are probably bang on.
    To be honest, I have a vague idea what these numbers mean but no idea if my numbers are in the ball park or totally unbelievable. The compression ratio should be 9.9:1. Again, no idea what that means. Can some one give us the short explanation?
    A.T.
    LOL. That actually ran through my mind, but I try to keep the Canadian jokes to a minimum. Too many Canadian friends to get off lightly!
    CR and psi are only vaguely related. CR is the ratio that the intake charge is compressed on the compression stroke, while the psi is the actual maximum pressure created in the chamber ( I believe it is gereated at TDC? ). Even if you had a hole in your piston, CR would still be the same (since it is a calculation) while you would generate no pressure (zero psi) since the cylinder would no longer be sealed.
    Did I miss anything?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. AFR Readings (LM-2) - Idle speed vs. Partial load
    By TEC69E in forum Technical Info
    Last Post: 02-03-2011, 05:59 PM
  2. 1970 911S compression numbers
    By surf in forum Technical Info
    Last Post: 10-05-2005, 07:34 PM
  3. Dyno readings
    By A67911S in forum Technical Info
    Last Post: 11-11-2002, 12:09 PM
  4. High compression test readings
    By Baddger74 in forum Technical Info
    Last Post: 02-21-2002, 03:30 PM
  5. Compression readings on early S
    By skid in forum Technical Info
    Last Post: 03-05-2001, 08:05 AM
