Thread: DIY install of external oil cooler questions...
    for those that have installed an external fender mounted oil cooler (28 brass style) to a car that did not previously have any cooler - how long did it take you? what was the drop in temp post install? any helpful tips? and the real dumb question: what size drill bit with original mounting hardware? thanks all!
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Aug 2003
    Van Nuys, Ca
    Hi Bob
    our experience with the brass coolers is mixed. They work decently on smaller displacement carbureted or mfi motors . As a radiant cooler the cooling is coming just as much from the fore/aft oem brass lines as the cooler itself! Actual temp drops on cars that install a system is about 20-25 degrees on average (how's the commercial go? your actual drop may vary)
    Anyway- it takes about 2-4 hours depending on your skill level and availability of parts to adapt a later system to an early chassis.
    best of luck
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
    Hey Bob, I'll be interested to see some replys. I'm in the same situation, but with a Mocal kit. Not sure I have the guts to start drilling into my car... but have to keep that refreshed motor refreshed.
    Tom Morgan
    Charlotte, NC
    '18 Carrera T - R #368, S #692
    1973 Giulia Super 1.3
    "As a radiant cooler..."
    - It isn't. It won't. Radiation will not be a significant heat exchange mode for any cooler ever used on a car.
  1. 911 S without external oil cooler/lines ?????
    By J.Puppi in forum Technical Info
    Last Post: 05-14-2015, 10:12 AM
  2. Need help with 28 Row external oil cooler tab
    By Haasman in forum Technical Info
    Last Post: 07-15-2013, 01:32 PM
  3. WTB: External oil cooler components correct for 73 911S
    By Haasman in forum For Sale: 911 Parts
    Last Post: 06-22-2013, 07:13 AM
  4. FS: External Oil Cooler Mounting Hardware
    Last Post: 08-14-2005, 03:35 PM
  5. Replies: 18
    Last Post: 07-14-2005, 07:32 AM
