Thread: HELP PLEASE:Loud groaning noise from right front wheel...
    Question HELP PLEASE:Loud groaning noise from right front wheel...
    Could this be a wheel bearing? If so is it something that could be fixed by an amateur with rudimentary skills? Any advice would be greatly appreciated.
    Tim,
    The first thing to check is if your lug nuts are tight...
    Next is to see if the bearings are out of adjustment...
    Jack the front of the car up and grab the wheel top and bottom (12 and 6) and see if you get any play... If so the adjusting procedure is in your owners manual...
    If your bearings need changing then get a repair manual (there's plenty out there) or seek professional help.
    If there is ANY doubt in your ability to repair ANYTHING that has to do with the safety of the car (suspension, brakes, steering, etc.) ... seek professional help.
    Hope this helps,
    Tim:
    Chuck offered very sound advice!
    I'd also add that such sounds can come from a dragging brake caliper. That can be caused by a bad rubber brake line or sticking caliper pistons.
    If you have ANY doubts about your ability to assess and repair this, get your car to a qualified and honest professional.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
  1. Replies: 3
    Last Post: 08-28-2013, 06:32 PM
  2. Early S on Fast 'N Loud tonight
    By JT912 in forum General Info
    Last Post: 06-17-2013, 07:39 PM
  3. loud when coasting
    By cmcfaul in forum Technical Info
    Last Post: 01-24-2010, 08:57 AM
  4. Right Front Knocking Noise
    By TripleR in forum Technical Info
    Last Post: 03-01-2001, 06:32 PM
