Results 1 to 7 of 7
Thread: Should this be black?
    I have a feeling this should not be black in my '68 S. It is the front end of the door trim.
    Thanks for your help.
    Henry
    Jul 2003
    Santa Cruz, CA
    I'm probably wrong and if so will shortly be corrected but, I think that the entire rocker trim you are showing is 69-73 and incorrect for 68. I think 67-68 S should still have the narrow trim strip and not the full rocker trim.
    At any rate you are correct. Black is wrong for that piece.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Apr 2004
    Consider yourself corrected (unless I'm wrong)
    Early 68 - the trim was changed, so Henry has the right trim but the caps should be the same anodized aluminum as the rest.
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    Henry,
    I might have an extra pair floating around. I will let you know if I can find them...
    Thanks Guys, I'm aslo sure that the trim is corrsct, it was changed in '68.
    Gruen, do let me know if you have a pair please. I'm going to try to remove the paint and polish them (which has worked well with other parts that were black in my car), but since these parts are "heavier use" given the location, a new pair would be great.
    Thanks again.
    Henry
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Henry,
    They usually polish up pretty well as they are stainless...you are correct that they are not to be black though.
    Cheers,
    Michael
    72 911S Coupe, Sepia Brown
    Jul 2003
    Santa Cruz, CA
    OK, I knew I was probably half right.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  1. FS: 1986 Tail Free Carrera Black/Black with Sport Seats
    By oscillon in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 09-27-2013, 12:26 PM
  2. FS: 350mm Momo Prototipo S Steering Wheel Black/Black
    By 68-911 in forum For Sale: 911 Parts
    Last Post: 01-10-2013, 08:15 AM
  3. 1960 356 T5B--Original Black Car w/Restoration Started & Black Ca Plates--$22500 OBO
    By gary basil in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 07-18-2012, 07:34 AM
  4. Replies: 0
    Last Post: 01-06-2012, 06:41 PM
