Results 1 to 2 of 2
Thread: Correct Rocker Detail - One More Try
    Porsche - There Is No Substitute 2POINT7's Avatar
    May 2005
    I posted this question in the Technical Info forum but got no response so, because I know somebody out there knows the answer, am trying again here. Please help me out if you can....
    Does anyone know for sure what the correct rocker panel finish is for a 1968 911? Is it body color paint? Black or other color? And very specifically, where does it start / stop? Any detailed information for this exterior trim area is appreciated.
    I tried to search the archives for this question but couldn't find a definitive answer. Thanks.
    Ed Cave
    Atlanta, GA
    Member No. 738
    1958 Porsche 356A Sunroof Coupe
    1998 Porsche Carrera S
    2008 Porsche Carrera S (her dd)
    2013 Audi A7 (my dd)
    joe912 joe912's Avatar
    Dec 2004
    Metepec , Edo. de Mexico
    Wink Rocker Panel Color
    Ed:
    According to the cars I have seen and also mine , the Rocker Panel should be in Body Color . This began from the exterior surface of the rocker curve(below the door) to where the Jack Stand Off or Jack support starts. Although I have seen that this support is sometimes painted in body color or in black (not painted!) they leave the natural color of the the Apko Seal or Anti-Chip (Corrosion Protective and Sound deadener) for originality purposes.
    I hope this helps.
    JL Garcia
    912, 1968
    Joe 912
    '68, 912
    Mexico
    Early 911S Registry # 1918
  1. FS: NOS Drivers Side Outer Rocker - Correct Early Stamping
    Last Post: 09-02-2009, 04:43 AM
  2. Correct wheelwell 67 SWB detail
    By Allen Henderson in forum General Info
    Last Post: 04-07-2009, 07:00 PM
  3. Correct position of alum. rocker trim?
    By ulrichd in forum General Info
    Last Post: 08-23-2007, 06:11 PM
  4. correct rocker deco treatment for late '67 911S
    By big_al in forum General Info
    Last Post: 03-01-2006, 08:35 PM
  5. Correct rocker panel finish
    By 2POINT7 in forum Technical Info
    Last Post: 06-15-2005, 03:54 PM
