Thread: How much does it weigh???
    Senior Member Homemade 911's Avatar
    Dec 2002
    China Lake - Third Rock From The Sun
    All,
    Does anyone know, right off hand, what the actual weight of a carb'd 2.0 engine, along with the 901 trans (less axles) is??
    I'm looking at buying one of those cheap ATV jacks, to facilitate drivetrain removal/installation. These ATV jacks look like a good safe way to "go solo" when yanking this stuff out of the car. They have a load rating of 1500lbs...Just want to make sure I'm not pushing my luck here - I realize the drivetrain doesn't weigh no stinkin 1500lbs, but an approximate weight figure will be real nice to have. fyi: I usually jack the car up level to sit on four stands, vs simply raising the backend...
    Anyone?
    Thanks for the help...As always, I appreciate the time.
    Happy 4th of July
    Cheers
    Thom Kuby
    Jan 2003
    UK
    Engine weight for 2.0L 911T (complete but without oil) = 184kg (~405 lbs)
    Transmission weight for 2.0L 911T (without oil) = 50kg (~110 lbs)
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Dec 2002
    Thanks, AndyJ!
    ...this is exactly what I was after, Thank You, Sir!
    cheers
    Thom Kuby
    Dec 2002
    Postscript...
    I found that the generic ATV jack wouldn't allow me to position it properly beneath the running gear. The handle (at least on the unit I looked at) does not crank down to the floor... So, I ended up buying an "ATV lift" adaptor kit for my long-reach shop jack. I found the kit (by accident) at the local Pimp Boys. This looks like a much tidier solution. Cheap, too. 40 clams.
    Happy 4th
    Cheers
    Thom Kuby
    Guys,
    Does the engine weight include or not include heater boxes and exhaust? Does the engine weight include the mounting bar and brackets at the rear of the engine? Is the weight with or without clutch and pressure plate?
    How bout the starter? Is that included in the trans weight?
    Just some of the questions that comes to mind when reading the spec book.
    The Capitalist Roader
    73 S with sporto and a 73 T coupe, soon to have a 2.7 mfi engine
  1. How much does an complete 2.2 or 2.4 MFI engine weigh?
    By execmalibu in forum Technical Info
    Last Post: 09-24-2010, 12:34 AM
  2. What's your "working Toolkit" weigh?
    By larry47us in forum General Info
    Last Post: 05-13-2004, 12:11 PM
  3. What's It Weigh?
    By 911SRegistry in forum Technical Info
    Last Post: 01-27-2001, 04:15 PM
