Results 1 to 8 of 8
Thread: HELP; 67S or not??
    Question HELP; 67S or not??
    Hello fellows,
    Can someone tell me whether this 67' 911 is an S or not? the chassis number is 305183. This is what the guy told me, but he could have forgotten to mention the S after the number. But even if it doesn't have an S after the chassis number, can't you still find a way to distinguish whether the car is an S or not?
    Erick
    Goldmember ttweed's Avatar
    La Jolla, CA
    Without the S after the 6-digit VIN#, it is likely a "Normal" '67. There are many ways to tell the difference, but the most important would be the Type number of the engine. An S had a Type 901/02 engine and the others would have Type 901/05 or 901/06. The engine serial number would start with "96xxxx" on the S instead of "90-" or "91-" on the Normals.
    Some of the "normal" 911 models were converted to S engines by previous owners over the years, though, so even this is not definitive if the engine is not original. The transmission type was 901/02 on the S model also, while the "Normal" had a Type 902/1 or 902/0 transaxle. There were suspension and trim differences as well, including the 4.5" x 15" alloy wheels, vented brake rotors, dash, rear ARB, leather steering wheel, etc., most of which could be optioned on the regular 911.
    HTH,
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Apr 2004
    Weber 40 ID S carbs (for the S) instead of ID A 's
    Oh yeah, and the "normal" normaly has the worlds biggest E-brake light below temp gauge instead of the combination oil temp/pressure gauge of the S (and the 65-66 non S ).
    But those can be swapped also of course.
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    John,
    Not necessarily. I recall reading somewhere that the early (late 66) 911S's came with IDA 40's.
    Apr 2004
    I could be wrong, but in the books I have the 901/02 only mention the 40 IDS
    Johnson shows that #s 305 101S - 307 360S (the early run) have the IDS
    Frere - Compared with the 901/05 used at the time ...the type 901/02 engine differed in the following main points " - the 4th diff. listed is "Type 40 IDS carbs (rather than the 40 IDA) "
    Also the Performance handbook lists the 901/02 with 40 IDS Webers.
    Though you wouldn't be able to easily check them Erick - the exhaust/intake ports
    are also different in the "normal" and the S. ..and the pistons......and...
    If it is a "Normal" - don't run away, they are still great cars - if the price is right.
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
    La Jolla, CA
    Quote Originally Posted by John Fusco
    This has been covered here before. 901/02 engines up to #960502 had 40IDA carbs, after that, they were 40IDS. See pg. 56 of BA's 911 Performance Handbook (2nd edition).
    TT
    Tom Tweed
    R Gruppe #232
    Read my surf novel!
    Apr 2004
    ... And I see that I even marked that passage (on pg. 56 in the PH) !
    I stand corrected.
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    The basket weave dash, the tach, the koni's, the carpet, the vented rotors, the Webasto
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
