Results 1 to 10 of 16
Thread: Engine number ID
    Engine number ID
    I am interested in an early '73T. I asked for the engine number from the seller & this is what he sent: 9011061015R .
    Is this really the engine type stamping rather than actual engine number (it doesn't seem to resemble red book info)?
    Could the '5R' at the end of this number indicate its not the original engine (73 is a 7R case correct), or is the info meaningless?
    thanks!
    That is the # on the side of the case. Castings changed in 73 so some have 5R and some have 7R. The webbing changed on the inside to support the bearings better. The engine # is located on the fan support right side and should have a 631xxx # if I remember correctly for T's. There is another # located there 911/xx that corresponds with it being a T, E or S motor. Hope this helps, if you post the # we can help discipher.
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Jan 2003
    NW Indiana
    The # 9011061015R is actually the casting # of the Magnesium fan housing not the case.
    Brian
    '71T
    R Gruppe #299
    Sorry got tunnel vision with the 5R thing.
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
    Thanks guys.
    The engine # he just gave me is 6201011 . This is a '72 engine, correct?? (my Red Book is @ home)
    Jan 2003
    NW Indiana
    Without my book handy either it looks like a 1970 E motor. Do you know what the type # is? That would be the 911/XX number.
    Brian
    '71T
    R Gruppe #299
    The red book says its a 1970 2.2E Sporto, 911/04
    Thanks. That is odd. The seller is not very knowledgeable, so possibly doesn't know that. From photos the shroud appears to be red (although its hard to tell 100%) so its probably impossible to tell what the engine has now become without any records.
    The VIN # is definitely a 73T, although the car has earlier style bumper guards. Is looking like a bit of a mongrel now!
    This is a good time to obtain and post pics of the car here for the experts to comment on. Even though it may be a mongrel, if you can pick it up reasonably and not have a ton of repairs to make, it *might* be an ok cruiser.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Sorry I haven't logged in to follow up on this one in awhile.
    The car was on ebay ( http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT ) & in the end the seller was very unresponsive to questions. He did send some small interior photos but never returned email or calls requesting front trunk & pan photos. He said the car had been repainted with some overspray but that was about all the info I gleaned. $12,000 seems high to me considering the 2.2 engine. I wonder if the winner is aware of that?
    In the meantime I have come across this fairly original 2.2T. Mechanically it seems in good shape, paint is original, but the car isn't rustfree as you can see. As far as the seller knows only the drivers door, rear trunklid & front bumper (surface) has rust, but I don't think he gets his hands dirty working on the car. If rust repair is needed is there any reason to pay a premium for original paint? If the rust is constrained to these areas is it even worth picking up a T like this w/ the intention of using it as a driver & gradually fixing it up, or does it sound like a money-pit?
  1. No engine number??
    By ccporsche in forum Other Porsche Passions
    Last Post: 06-03-2013, 06:26 AM
  2. looking for 72S engine number ?
    By manu72S in forum General Info
    Last Post: 04-09-2009, 09:36 AM
  3. Need help with engine number ID
    By Polizei in forum Technical Info
    Last Post: 07-03-2008, 04:21 PM
  4. Engine number
    By hdavis in forum General Info
    Last Post: 03-11-2004, 08:16 AM
  5. Engine Number help
    By Vintage911racer in forum Technical Info
    Last Post: 11-15-2003, 07:39 AM
