Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: rivits on factory plate
    Can you restoration experts out there tell me if these look like the original rivits on the factory paint plate?
    I know the car was repainted once (it was a custom gold color, and a PO changed it to red). You can see the red on top of the plate in places (also there are curved swirl marks at each corner - maybe a buffer or sander hit the plate). That makes me think the plate was not removed before.
    Any other thoughts on this plate? ways to make it nicer (restore it) or should I just leave it alone?
    - this is the best image that the forum software will let me post; if you need more detail, I can post it on Pelican and then put a link to it here.
    Thanks!
    PM'd you, Randy.
    Best,
    Tom
    Early S Registry #235
    rgruppe #111
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Randy,
    Stoddard stocks these special rivits for $.05 each...pretty spendy I know, but hey, your cars worth it... Although, I am not sure how these attach as my standard Stanley rivit gun will not work with them...
    They look to be original though to answer your ???
    Cheers,
    Michael
    72 911S Coupe, Sepia Brown
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Rivets
    RGruppe #183
    Thanks -- Stoddard's told me they did NOT have them and could NOT get them.
    Guess I need to talk to somebody else there... any names??
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    they look good to me
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
    Suffolk, VA
    I would avoid removing that door jamb plate (paint code) - the one with those funky rivets - at all costs. Those are not "blind" rivets, which you can pull with your "stanley" rivet gun. Those look like normal rivets which require access to the back of the plate to buck them. Lotsa luck.
    Citation F1000 on the way
    Other Early 911/912/914
    I think the painter is going to drill them out. He definitely wants the plate off...
    Bad idea??
    Suffolk, VA
    Well... you could replace the plate with the proper non-blind rivets by epoxying them in place, if you can find them.
    Aug 2003
    I just ordered the ones above from Stoddards. They are also used on a 356 plate. Randy, since you are painting the car, the doors will be off...with the doors off, you can see the back of the panel and install them properly.
    Cheers,
    Michael
  1. Fan Restoration - Rivits?
    By Fishcop in forum Technical Info
    Last Post: 02-11-2013, 08:06 PM
  2. FS- Original SWB Factory Radio Delete Plate
    By 72tii in forum For Sale: 911 Parts
    Last Post: 10-20-2012, 06:21 PM
  3. WTB Factory Radio Delete Plate for 67.
    By JKW in forum For Sale: 911 Parts
    Last Post: 06-08-2011, 03:44 PM
  4. Mounting Factory Rear Skid Plate
    Last Post: 08-17-2008, 05:58 AM
  5. Halda/Heuer Factory Support Plate
    Last Post: 12-08-2007, 08:25 AM
