Thread: ITG filter set
    ITG filter set
    ITG air filters. These are part no. JC40-40. New and unused. Comes with two sets of mounting plates as shown; one pair is blank - you drill/cut for your application. The other has been precut. PO says they were for a 906 engine (not verified). These will not fit regular Webers as the short height interferes with normal-height velocity stacks. $230.00
    Enclosed are a couple of pics with the same size filters (not mine).
    Sherwood
    FWIW, add'l notes from PO:
    1. In my application I was using weber 46 carbs with 906 intake manifolds. These are taller then standard ones. It is a tight fit to clear the bulkhead.
    2. However with a normal set up using weber's - no problem. They can be used with MFI as well, but you have to notch for the cold start squiter. regular velocity stacks are no problem.
    ITG filters
    Hello: What is the height of the foam filter on the inside? Are you looking for any parts? Thanks Eric
    Eric911s,
    Sorry about the delay. I just had a chance to measure the filter.
    Inside, there's 45mm of space between the al. mount plate and the plastic filter structure.
    Hope this helps,
    Sherwood
    ITG filters
    Hello: Sorry they are not tall enough for the air horns I'm running. Thanks Eric
  1. Which oil filter?
    By Merv in forum Australia
    Last Post: 12-31-2013, 05:40 PM
  2. New K&N air filter
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 02-12-2011, 07:53 PM
  3. WTB '65 /'66 Air filter
    By egbert in forum For Sale: 911 Parts
    Last Post: 02-08-2011, 01:10 AM
  4. WTB: oil filter base
    By mcaterino in forum For Sale: 911 Parts
    Last Post: 02-01-2011, 11:06 AM
  5. FS: K&N FILTER set ups (2)
    By Sacto S in forum For Sale: 911 Parts
    Last Post: 11-12-2008, 04:11 PM
