Results 1 to 2 of 2
Thread: Engine Noise!!!!!!!
    Mar 2005
    Unhappy Engine Noise!!!!!!!
    Today I noticed for the first time a noise coming from the engine. The noise is a metallic clunking sound that occurs at about 10 second intervals and does not speed up if the rpms go up. Could this be the timing chains skipping or jumping?
    don
    Anything that is moving inside the motor that clunks should change with RPM. Tensioner failures shouldn't clunk. Deep clunk are usually rod or crank knocks from too much bearing clearance. Is oil pressure OK? Does noise go away when motor heats up. Be very careful you don't want anything to fail it can get expensive when internal parts break.
    Good Luck,
    Phil
  1. Help identifying engine ticking or clicking noise
    By SpawnyWhippet in forum Technical Info
    Last Post: 08-25-2017, 01:39 PM
  2. What is that noise?
    By raspy2point2 in forum Technical Info
    Last Post: 03-30-2010, 08:59 PM
  3. Grumbling Noise
    By boxster03 in forum General Info
    Last Post: 02-26-2008, 07:30 AM
  4. transmission noise?
    By james in forum Technical Info
    Last Post: 01-05-2004, 11:57 AM
