Thread: 911R Wheels
    911R Wheels
    Does anyone know if 911R wheels fit on the rear of a 1972 911
    without fender modification? Can you really run 225's without
    rubbing? Many Thanks
    I am running 7Rs on a 71 car with 215 tires. I also use a 5mm spacer as without this the tire rubs the inner arch.
    Alan.UK
    Quote Originally Posted by JDStell
    Yes, but you need upgraded torsion bars, sway bars, shocks, plus additional negative camber, shaved spring plate bolts and 8-16mm spacers with longer studs.
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
    7x15 Fuchs
    Hello: You can run late style 7x15 Fuchs with 225/50/15 as long as you don't lower the car too much. These wheels are alot cheaper than 7R wheels. Lets see you could buy about 6 late wheels in great shape for 1 7R wheel. I run this setup on many 911's that are run on the track. Thanks Eric
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    I am running late 7x15s on my 69 912 with 205/55 and my car is lowered a LOT. No spacers. The 225 wouldn't quite make it I don't think.
  1. all we ever needed to know about 911R wheels
    By mjshira in forum Technical Info
    Last Post: 12-02-2011, 10:36 AM
  2. FS: Complete set of 911R Wheels
    By a911s in forum For Sale: 911 Parts
    Last Post: 06-01-2006, 11:02 AM
  3. FS: 911R wheels
    By K.B. in forum For Sale: 911 Parts
    Last Post: 08-09-2005, 05:45 PM
  4. 911R wheels
    Last Post: 04-10-2004, 10:10 AM
  5. I want to make 911R wheels!!!
    By SprintStar in forum Technical Info
    Last Post: 09-03-2003, 01:01 AM
