Results 1 to 2 of 2
Thread: Brake Master cylinder renewal?
    Question Brake Master cylinder renewal?
    Hi all,
    here's another newbie question: how can one tell when one needs a new brake master cylinder? Or maybe just need to 'revive' it....
    Mine has the little rod sitting between the pedal and the cylinder coming out real easy, is that supposed to be like that? Also, after the rod came out, brake fluid was coming out as well. To me, it doesn't look very safe etc., the car passed it's yearly MoT check though.
    Any clues?
    Dennis
    Dennis de Vlaam
    ....and on and on and on goes the 911 resto....
    1972 911S ----> 1972 911S
    1999 Lotus Elise
    1999 BMW Z3 coupe 2.8
    2005 Ford Mondeo Titanium
    Goldmember ttweed's Avatar
    La Jolla, CA
    If fluid is leaking out the rod end of the cylinder, then the piston seal has failed. You can rebuild them with a new seal kit, but check the bore for roughness-- if it is too pitted or scored, you might be better off with a new cylinder. They are not THAT expensive, compared to the alternative of brake failure....
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
  1. FS: NS-OS Brake master cylinder, reservoir and strap
    By X-Faktory in forum For Sale: 911 Parts
    Last Post: 12-26-2012, 04:59 PM
  2. Need Brake Master Cylinder Piston
    By red911 in forum Technical Info
    Last Post: 10-08-2011, 09:40 PM
  3. Brake Master Cylinder 23mm New
    By Dmill in forum For Sale: 911 Parts
    Last Post: 09-24-2011, 05:21 AM
  4. 23mm brake master cylinder, anyone using?
    By goofycarp in forum Technical Info
    Last Post: 12-02-2004, 02:43 PM
  5. Brake master cylinder
    By herrongrey66 in forum Technical Info
    Last Post: 09-12-2002, 11:54 PM
