Results 1 to 10 of 10
Thread: 69 S Head ID
    69 S Head ID
    Fellows,
    Is there a way to identify 69S heads without resorting to measuring the valves? Do they have a unique part number? If so, which is it?
    I have various sets of heads available and want to ID them quickly (without having to go through the whole pile...).
    I'm looking for more S heads by the way!
    Thanks in advance, Juan
    I have 3 heads dated 10/68 still attached to cam housing.$150 + shipping for all. Interested?
    RPM, are those 69 S heads? 39/45mm valves?
    Just picked another set of heads on ebay... collection growing.
    Still looking for 2 liter 69 S heads...
    Jan 2003
    UK
    Juan - I'm fairly sure all the 2.0 litre heads used the same basic casting.
    Easiest way to identify the S heads is either from the valve sizes or port sizes - S ports are 36/35 whereas L/T/E are 32/32.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Andy,
    I'm afraid you are right. I was hoping there was an easy way to have someone go through my boxes of stuff (which are stored away from my place) without having to resort to a caliper to measure heads and ports.
    Thanks SO much. Cheers, Juan
    69 casting number.
    Hello: The heads all have different casting numbers. I will look to see what the casting numbers are on the 69 S heads and the E heads as well. 69 S heads are worth some money, so I will buy any you have. I also use E heads ported and they work very well. Thanks Eric
    Eric,
    I appreciate the info on the part numbers !
    I must get another complete set of 69S heads as I'm trying to build 2 additional (spare) engines. Any leads?
    Cheers, Juan
    2.0 heads
    Hello: Juan, I found the 2.0S heads of mine and the casting number is 901.104.308.1R. I will have to check the other garage for the 2.0 E head casting number. Do you need any fuel injection parts? Or 80mm pistons from a 906. Let me know what you are looking for I may have it. Give me some time to find it, I have alot of projects right now that need to go out yesterday. Thanks Eric
    Thanks much Eric. I replaced the MFI on the race car with PMO 46's and use Cosworth pistons.
    I might need parts for my other 69 S though. Not pistons but my MFI is acting up...
    Once I go over it I'll now. Thanks SO much!
  1. FS: Head Studs and head Nuts
    By cmcfaul in forum For Sale: 911 Parts
    Last Post: 04-26-2014, 06:48 PM
  2. WTB: 69S 2.0 head
    Last Post: 01-06-2013, 03:59 PM
  3. 2.4S Head WTB
    By 9146racing in forum For Sale: 911 Parts
    Last Post: 01-08-2011, 07:59 AM
  4. WTB 67-68 S head
    By 912-2.8 in forum For Sale: 911 Parts
    Last Post: 12-17-2006, 10:39 AM
  5. Perplexing head - MFI in a 67 code head?
    By kenikh in forum Technical Info
    Last Post: 02-01-2006, 11:04 AM
