Any help on purchasing rear rotors outside dealer network greatly appreciated. Dealer list is 350.00. a touch strong!
Not sure of the pricing, but I recall reading a thread (here or Pelican, can't remember which) suggesting the use of cut down 944 rotors as a replacement. A search of both boards should yield some results for you..
Brake Rotor, Rear, 356C/911/912 Ref: 901.352.401.10
Solid brake rotor
Made in Germany
Fits:
356C 64-65
911/912 65 -68
Reference/Interchange Numbers:
90135240110
901.352.401.10
90135240111
901.352.401.11
Price: $83.95
Bill Conway, Early S Registry member #254
1970 S, 2.2L Silvermetallic Coupe
1973 T, 3.2L Black Carrera Targa
1969 T, 2.4L Silvermetallic Targa
901 352 401 10 Rear Brake Rotor
Rear Brake Rotor
Rear Brake Rotor
911, 1965-68, non vented rotor
912, 1965-68, non vented rotor
Compare At :$247.73
Ships in 1-2 business days
$89.95
The S rotor is vented not solid. Get a 944 rotor modified as mentioned above
http://forums.pelicanparts.com/showt...0&pagenumber=2
See link above. Get a 944 Rotor '83-'84 and machine the radius down to 285mm. It fits perfect once machined down. E-brake needs no mods just an adjustment.
Bret Davis
1968 911L
it's not often, but you guys are a real help in comparison to 40 years ago when we were all on our own!-Mark-formulamotorsports.com
Apologies to all - I was not aware that vented rotors were available prior to 1969 S's - but then I don't know much about the "O" series at all, unfortunately. I'll be quiet now...Originally Posted by nick-moss
