Thread: Engine Compartment Pad
    When Mike restored Kermit, he replaced the engine compartment pad that backs up against the rear seats with a new one. Well, the foam looks nice, and seems to be cut right, but the damn thing has fallen down. It won't stay stuck against the rear seat backs. It's just floppy in there.
    Any suggestions? I thought of some double sided tape, but I'll bet that the heat will keep the adhesive from sticking.
    larry
    06 - Lexus IS250 MT6
    98 - Volvo 70V XC
    I've always used the 3M Spray Adhesive (trim/carpet etc) with good results. You have to shoot both items. Shoot the engine firewall/back seat and then the back of the pad. Now, here's the trick. You have to let it "tack up" before applying the pad. That's tough with the engine in but it can be done.
    Good luck,
    Tom
    Early S Registry #235
    rgruppe #111
    The 76 Series seems to have a high temp spec.
    I am going to try to locate this formulation.
    1970 911S Targa
    On the road again soon.
    100 tubes of super glue
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Oct 2005
    Minneapolis, MN
    We brush on contact adhesive......but the 3M spray stuff layed on heavy works well too.......yes spray both and let it set up.
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
  1. WTB: Engine Compartment Labels
    By Larryg57 in forum For Sale: 911 Parts
    Last Post: 05-18-2010, 04:23 PM
  2. engine compartment light for a '67
    By CarmelSkip in forum Technical Info
    Last Post: 03-14-2009, 06:24 PM
  3. Engine Compartment light
    By rcnagel in forum Technical Info
    Last Post: 08-19-2008, 12:48 AM
  4. What is the color of your engine compartment?
    Last Post: 06-20-2006, 05:40 PM
  5. Engine Compartment Stickers
    By HarryD in forum Technical Info
    Last Post: 08-05-2004, 08:01 AM
