Thread: Sensor on oil breather
    In my pursuit of putting MFI back on my 2.0S, I have been acquiring lots of parts. The latest is an MFI oil breather. The sensor on the cover seems to damaged and I don't see a replacement on Pelican. Tell me these are not NLA...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    After looking at the microscopic print on the thermo-time switch, I found a part number. Looks like it can be special ordered.
    Yeesh, they are kinda expensive @ $64.05. What is the risk of using one which has the plastic spade in the middle broken? Is there any way to test this part off of the car?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Is that really where they put that sensor for MFI?
    Seems like kind of an odd location to me, would the sensor even be in oil there?
    Joe
    Now - 1993 C2
    Past - 1968 911L
    Its not a conplicated affair... Its only a thermo switch to sence if the motor is cold enough for added cold start enrichment.
    Its easy to check if it works or not.. and dime a dozen at a dismantler if you want used.
    Robert.
  1. WTB: Oil Tank w/level sensor for 69 911T
    By Perry911 in forum For Sale: 911 Parts
    Last Post: 06-18-2013, 11:04 AM
  2. 71T Speed Sensor Causing No Spark?
    By Stretch32 in forum Technical Info
    Last Post: 04-15-2013, 01:14 PM
  3. WTD Oil temp sensor for 68 (Porcelain style)
    By beetle08 in forum For Sale: 911 Parts
    Last Post: 12-02-2012, 11:08 AM
  4. pressure sensor 901.741.551.01 on a -67
    By Johan H in forum Technical Info
    Last Post: 06-13-2012, 03:56 AM
  5. WTB: LM-1 O2 sensor
    By orange911 in forum For Sale: 911 Parts
    Last Post: 05-19-2009, 07:22 AM
