Thread: headliners
    Smile headliners
    Has anyone installed a new headliner in a coupe? Any hints? Front and rear first and then the sides? Or sides first?
    Ed B
    Dec 2004
    Front and back working from the center out to the sides
    Do it when the weather is warm to hot. The vinyl will strench a little better.
    Get a box of file clips from Staples too. The little ones with the arms. They work great to stretch it into shape before gluing.
    I've never done a headliner on a 911, but putting the headliner in the sun for a while will make it much easier to work with.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Suffolk, VA
    I did this only once before - in the California sun. I first installed the headliner bows through the headliner and installed in the roof - to get it in roughly the right spot. I then did the front and rear sections - held in place by those little clips (that come off with the old headliner). I then did the sides with those clips too (you will need more of those little clips). Also, I used contact cement applied with a very small paint brush. As usual, measure twice and cut once (like the light cutouts). Good Luck
    Citation F1000 on the way
    Other Early 911/912/914
    Headliner
    Thanks for the suggestions.
    Ed B
  1. SWB Headliners
    By merbesfield in forum Technical Info
    Last Post: 08-17-2019, 09:29 AM
  2. Replies: 5
    Last Post: 12-17-2011, 10:11 AM
  3. Replies: 3
    Last Post: 07-27-2011, 02:12 AM
