Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: MFI fitment checklist
    I have been putting together a simple spreadsheet listing all of the things I think I need to hand off my MFI for installation. Does anyone see anything I have missed that belongs on this list?
    Yes are the things I have, No means I don't and ? means I don't kow if I have them or not.
    Attached Files Attached Files
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    How about..
    The insulated hose that goes from the Pump to the Left heat exchanger
    The proper MFI heat exchanger(s)
    Air cleaner assy with priming system (optional,depending on year)
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
    Quote Originally Posted by silverc4s
    I'm going to have my SSIs modified for the warm air pipe...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    If by "spray bars" you mean the bars running through the air cleaner housing designed to squirt gas into the top of the stacks for cold start? DON'T DO IT! Extreme fire hazard...go to the '72 or '73 cold start system if you can...or live without a cold start system.
    Quote Originally Posted by pwd72s
    I have been struggling with this. I want cold start, but the fire hazard bugs me. How much work is it to adapt a '69 system to a later cold start?
    Now back to the list...am I missing anything?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Apr 2003
    Somewhere in Texas
    Kenikh,
    I do not have the cold start priming system connected on my 70, and I don't miss it. If you are in a warm to temperate climate, don't think you will need it.
    Back to parts:
    Oil line from engine to pump w/clamps
    MFI oil line fitting on top of engine
    Define cold; Seattle can be very COOL and wet. Then again, since it is garaged, might not be an issue. I am really annoyed by the Webers from cold start, though. No chokes BLOWS. If it is anything like that, I am going to add cold start if it kills me (or burns me )
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    If I don't go with spray bars, is this a reasonable alternative:
    From Supertec:
    MFI FUEL ENRICHMENT
    Finally, a way to make your early Porsche fuel injected engine run well when it's cold. Easy installation and operates off a simple cable from the drivers seat. Clean, easy and it works!!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Hose to ssi's
    Kenik: If you use the Supertec enrichment lever in the photo then you won't need the heat riser hose to the enrichment/ warm up plunger. Also for cold start use a button to opperate the squirters instead of the cold start solinod. You just press the button for a count of 3 then turn the key. It will start every time and less risk of a fire. Also on your check list you need the MFI vent cover,oil pressure banjo screw for pressure line, temp sensors. Thanks Eric
    I have the vent cover and temp sensors, but I am not sure about the banjo screw. Where does it go and what does it look like?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. Door fitment SWB
    By Bradford in forum Technical Info
    Last Post: 12-06-2013, 07:56 PM
  2. SWB Ext Oil Cooler Fitment
    By 50/50 in forum Technical Info
    Last Post: 03-10-2012, 04:29 PM
  3. H-1 Fitment
    By MY911S in forum Technical Info
    Last Post: 11-29-2011, 01:59 PM
  4. 7R Fitment
    By CamBiscuit in forum Technical Info
    Last Post: 03-30-2008, 07:21 PM
  5. RS Oil Cooler Fitment
    By JuanLopez in forum Technical Info
    Last Post: 02-05-2002, 07:14 PM
