So, has anyone dialed in the definitive ST flare shape and measurement? I f someone was going to make an ST replica, what would they do to make the flares?
Comments?
Comments?
1974 911"S" - Silver
10 sec 67 VW
Early "S" Registry #439
I had a set on a 72, I could dig out a picture or two but that might not help. They have a countour much more like a turbo flare but are 9" not 11" they look great, I had a set of 9 x 15 fuchs on the back which also looked great.
Phil
I believe there is someone who is a member working on ST flare contour measurements and possible replication. Maybe he will chime in. You could start with SC/RS flares and stretch/add metal for the rears, or start with Turbo metal flares and remove metal front and back.
Randy Wells
www.randywells.com/blog
www.hotrodfilms.com
Early S Registry #187
When a flare is described as 9" or 11" where is that measurement taken? Never quite understood the term and how to acurately define it.
10 sec 67 VW
Dave, the 7, 9, or 11" flares accept 7, 9, or 11" wheels. That's the measurement; how wide a wheel they were intended for.
RGruppe #183
Hang on guys, I'm workin on it. I will keep the board posted.
Cmon Rick, you gotta give us more than that!
10 sec 67 VW
A friend of mine owns the ex-Bjorn Waldegaard 1971 RAC Rally ST. He did a lot of research with Jurgen Barth when he restored the car and found out that his car came from the factory with no flares, got custom 9" flares at the rear then 9" flares at the front as well over a 12 month period. The flares were hand made in steel so no 2 cars, even 2 sides of the same car, were identical. That said there is a definite "style" to ST flares amd Steve Monk, of Bodywerkes in the UK, has built several ST replicas with steel wings from his original work on the Waldegaard car.
Maybe there:http://stimming.de
We are going to make rear steel ST flares at SG Racing for next project,all infos are welcome!!!
#rennfrog
