Thread: Indicator Lamp Question
    Porsche - There Is No Substitute 2POINT7's Avatar
    May 2005
    In a '73S, the temperature / oil pressure guage is to the left of the tachometer and has a red indicator light at 12 o'clock and at 6 o'clock. Can someone tell me definitively what the indicator light at 12 o'clock indicates?
    I suspect it indicates that the hand brake is activated. Is that correct?
    Thanks very much.
    Ed Cave
    Atlanta, GA
    Member No. 738
    1958 Porsche 356A Sunroof Coupe
    1998 Porsche Carrera S
    2008 Porsche Carrera S (her dd)
    2013 Audi A7 (my dd)
    Ed,
    You are correct...
    Here's the page you need from a '73 owner's manual...
    Hope this helps,
    May 2005
    Thanks, Chuck. I have an apparent short somewhere and that lamp flickers off and on frequently. Sitting as it does at the very top of that small oil temp graphic, just wanted to be sure it had nothing to do with oil as you might think it would considering its location.
    Thanks very much.
    Ed Cave
    Atlanta, GA
    Member No. 738
    Apr 2003
    Portland, OR
    If you do not have a wiring diagram for your car, Pelican Parts (www.pelicanparts.com) in the Tech info section has a 1973 wiring diagram. You can see how the light is wired anduse this to troubleshoot this circuit.
    Ususally, you will find the problem to be:
    1) a short in the wiring;
    2) A failure of the switch in your master cylinder; or
    3) A failed or misadjusted microswitch on your handbrake.
    Harry
    Member #789
    2009 MB C300
    won't it also show low brake fluid on the '73?
    Apr 2003
    Portland, OR
    Randy,
    Looking at the wiring diagram, the light is activated by either the switch on the master cylinder (that activates when you lose fluid in the braking circuit) or the microswitch activated by the handbrake. Later cars may also have a level sensor in the brake fluid reservoir but (at least my) '73 does not have this feature.
    I had the switch on my master cylinder go bad (corrode) and turn on this lamp.
    Harry
    Member #789
    2009 MB C300
  1. FS: a few tail indicator lenses and one front indicator lens
    By fourteenten in forum For Sale: 911 Parts
    Last Post: 04-09-2014, 08:32 AM
  2. 73 S - optional engine lamp question...
    By mac73s in forum Technical Info
    Last Post: 07-23-2013, 06:43 AM
  3. Hi beam indicator on 73 E
    By cmcfaul in forum Technical Info
    Last Post: 03-30-2012, 10:45 AM
  4. 911 front indicator ID question
    By lisa_spyder in forum Technical Info
    Last Post: 10-12-2006, 03:14 AM
  5. indicator seals - quick question
    By pgxif in forum Technical Info
    Last Post: 08-12-2004, 08:38 AM
