Results 1 to 9 of 9
Thread: HELP, WTB Sport seat reclining hinge
    I went to install a sport seat this week to find out that the restorer didn't first check the condition of the hinge. Shipping to me worldwide is OK. Attached is a photo. 67-73 are pretty much the same. Hinge for the driver to adjust, and just a pin in a hole on the other side.
    I believe these are similar to the hinges on all the early seats. I can refinish a chrome one like the black one if you'd like. BTW, BMW 2002s used a similar hinge. Try "2002AD", a break yard for early BMWs.
    Mike
    Vollgas!
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    Rick i think i can get you one just like it, will check with the guy tomorrow.
    Seattle WA
    Quote Originally Posted by flat6s
    Mike
    I found a set of those, and they don't work...I tried.
    Guys,
    Thanks all for the responce!
    As Eric said, the chrome hinges will not work! To many holes in the wrong place.
    Platas, I'll wait for you.
    Thanks, Rick
    Wow, I never tried to interchange these. They do look very similar though. I guess that is how Recaro was able to keep them "unique" for each marque.
    Mike
    Vollgas!
    Apr 2004
    Denver, CO
    Are these hinges the same as on 74-80 sport seats? They look pretty similar to mine.
    Carl Bauer - OBP
    1979 RoW 911SC
    Seattle WA
    Yes, they are similar....you need to tap one more hole in the 74+ style to make it work.
    Eric
    The 74-77 sport seats have a similar set up. But... those seats have a hinge on each side connected by a internally splined rod. Yes, dimension wise, the hinge is the same, but as Eric said, you would have to add a hole in the lower section, and be spot ON where you drill it or you would have a wasted hinge. Also, if you were to look behind the seat back you would see a splined shaft about a inch long going nowhere. This would not impress a concour judge.
  1. looking for sport seat driver hinge pre 80's
    By EARLY911ZOO in forum For Sale: 911 Parts
    Last Post: 09-14-2012, 08:54 AM
  2. Seat Hinge Lever
    By Jacket in forum Technical Info
    Last Post: 09-04-2012, 04:50 PM
  3. NEED: Reclining Seat Brackets (Chrome) 1967
    By FHernand in forum For Sale: 911 Parts
    Last Post: 01-01-2009, 04:12 AM
  4. Replies: 3
    Last Post: 06-24-2008, 02:56 AM
  5. Two NOS non-reclining Recaro sport seat bases
    By M491 in forum For Sale: 911 Parts
    Last Post: 03-25-2008, 02:37 PM
