Results 1 to 10 of 20
Thread: What's more acceptable for "R" project?
    I am debating using a 912 for an "R" project.... is that more acceptable than losing another 68 911 as a donor??
    I know 68 911's aren't crazy valuable but still, there seems to be a gazillion 912's and I do not see them climbing in value all that fast.
    Just want another opinion..... but aside from that angle would there be any other reason not to use a 912 as a donor? (It will go to 6 cyl too)
    THANKS
    Nov 2002
    Worshington State
    Don't think that acceptibility enters into it. Many a T is converted into an RS or RSR replica. Sounds like you found a very cost effective donor to build your R. I say go for it (and be sure to show me the result).
    Sounds as good a use for a 912 as anything.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Russian,
    I have been thinking about the same thing lately...
    I believe Kurt zimmerman's car started out as a 912 and well...it's pretty badass.
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    Quote Originally Posted by kenikh
    Yup, no 911 elitism here
    Cheaper to build a big Type 4 powered 912 - missing the howl of the 6, but fun on a budget! There are a lot of affordable 12s on Ebay and since the 356 based engines have a tendency to die early deaths, why not?
    912/911 race cars
    Hello: Do it then it will be one more car on the road. I'm finishing up a 912 engine and will tell you it costs more to rebuild then a good 911 engine. Take a look at some 911 race cars sometime and look at the engine mount area. You will see the old 912 mounts ground off. The 912 will make a wonderful conversion car and the chassis don't tend to be bent up or crashed as bad. Good luck with your project. Thanks Eric
    Quote Originally Posted by lkadams
    I wasn't trying to be a 911 Elitist; it seems as good use for a 912 as a 'T' or 'E' or 'L' would be for this purpose. Perhaps I am an 'S' elitist; I would never condone converting an 'S' car to an 'R' replica.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Thanks for the encouragement!
    Does it really cost the same or more to re-do a 912 engine??!!
    I am planning a stock rebuild w/ upgrades in the interim.... it will get a full six cylinder at a much later date along with all the other FG mods.....
    I figure the price of admission was a no brainer, so here it is:
    1968 Arizona car, some rust not bad, not beat up just driven.
    4 cylinder options
    Another option, though expensive, could be a Polo 4.
    http://hillmanimages.com/912/040201-5136.html
    I think he can make a 3.0 litre version putting out 200+ hp.
    Cheers,
    Kevin
    RGruppe #004
    "Shoemaker stick to your last,"
    Ferry Porsche
  1. FS: @Pelican - Semi-completed "73" 911 RSR Project based on 79 SC
    By 72targa in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 01-30-2013, 12:16 PM
  2. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 01-24-2012, 01:59 PM
  3. Replies: 49
    Last Post: 09-23-2010, 12:30 PM
  4. 70-73 911 "driver condition"/ or project wanted - So. Cal.
    By early911socal in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-16-2009, 01:04 AM
  5. Early 911 "project"
    Last Post: 07-18-2005, 06:52 AM
