Results 1 to 7 of 7
Thread: Tire pressures for 205/60HR/15 ??
    What are people with these size tires running for air pressure
    front & rear ?
    I thought my Dunlops were a bit soft in the sidewall until I checked
    the pressure & found only 23 psi front/rear
    I did a search, no answer...sorry if this has been covered
    already 1000 times !
    thanks
    1973 911E Viper Green
    2021 Spyder PTS Signal Yellow
    2019 Carrera T Racing Yellow
    2008 Boxster S Ltd. Ed Orange
    2007 911 GT3 Meteor Grey
    @Type911 instagram
    RGruppe #295
    Zuffenhausen secret weapon
    I have always heard that you are suppose to run your tire air pressure based on the particular cars requirements, not the particular tire. I think that would be 26 front and 29 back for early S
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Are you autocrossing? Or just going to the grocery store?
    Peter Kane
    '72 911S Targa
    just looking for around town/hwy spirited driving pressure rec.
    @Type911 instagram
    RGruppe #295
    Goldmember ttweed's Avatar
    La Jolla, CA
    You could always look at the little foil sticker on the car that tells you what the factory wants you to run.
    For street driving on my 205/60-15" Michelins, I use 29F and 31R cold pressures on a 2370 lb. car. For "spirited" driving, I would bump that up a couple of pounds.
    For R-compound tires, it's a whole 'nuther ballgame.
    YMMV,
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Tom,
    Thanks...yes I did look at the foil sticker, but thats for 185/15's
    I'll try 29/31 !
    Thanks again
    @Type911 instagram
    RGruppe #295
    Apr 2003
    Portland, OR
    Quote Originally Posted by Type911
    front & rear ?
    thanks
    When I had my old 205/60-15's (Toyo Proxes H4 M&S - aka flintstone mobile tires) I ran 29 F/32 rear. Ride comfort seemed ok and tire wear was normal. At AutoX, I raised the pressures by 5 psi to stop the side wall from rolling over.
    Harry
    Member #789
    2009 MB C300
  1. Auto X Tire Pressures
    By Gumby in forum Technical Info
    Last Post: 03-13-2013, 02:42 AM
  2. Replies: 2
    Last Post: 10-09-2012, 02:47 PM
  3. VDO Tire Gauge
    By joegt3cup in forum General Info
    Last Post: 03-03-2009, 08:58 AM
  4. tire help
    By steve shea in forum Technical Info
    Last Post: 08-20-2007, 10:02 AM
  5. Pressures
    By AndyR in forum Technical Info
    Last Post: 04-05-2001, 07:39 AM
