Thread: Front pan drain tubes
    Oct 2004
    SW Suburbs of Chicago
    I can't find reference in my parts manual to the two rubber drain tubes that fit in the holes in the bottom of the front pan. They are tubular and flattened out at the end. Are these available and what is the part #? Thanks
    Oct 2004
    I'll answer my first ever post with my second ever post. Should have done more research before posting: Stoddard has them, part # 911.025.612.00 for about $3 each.
    Thanks, I need those also
    also similar items in the R taillights & F headlight buckets...
    put them in water and smear a little soap or dishwashing liquid on to help them slide into the holes.
    The Netherlands
    drain tubes
    The drain tubes in the headlight buckets and rear tail light assemblies are different 911-631-259-02, a round top and not flattened at the bottom.
    Cees
    drain tubes on 1970S?
    Do all early 911's have drain tubes? I can see clearly the holes the tubes go into in the trunk of my 1966 911. However, I don't see any similar holes in the trunk of my 1970S.
    Lee
  1. WTB 65-68 front cowl drain tray
    By xpensivewino in forum For Sale: 911 Parts
    Last Post: 05-09-2012, 08:28 AM
  2. front cowl drain tray
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 04-01-2012, 12:30 PM
  3. Wtb:drain plugs
    By 71-911T in forum For Sale: 911 Parts
    Last Post: 01-11-2012, 04:25 AM
  4. SWB Front Bumper Mounting Tubes
    Last Post: 04-05-2010, 06:24 PM
  5. FS: Drain tube front trunk and rear tailight housings
    Last Post: 10-25-2009, 11:59 AM
