I bought this Marelli twin plug cap for a client of mine. It was said to be for a 2.8 RSR but it is different than the correct examples I have here.
Can anyone tell from the picture what it might be for?
Aaron
Aaron
ooops....I forgot....it's the newer looking one on the right...
Aaron
Hello: If the coil plug-in boses are different heights then you have a Jaguar cap from a 80's v12. I see these for sale alot and unknowing people buy them since they are told it is for a Porsche. Look on e-bay under Marelli and you will see they sell these caps. You can get a reproduction cap from Andial I think. Good luck in your search. Thanks Eric
As Eric hinted above - the cap on the right is for a V12 Jaguar XJS.
Unfortunately many buyers are being hoodwinked into thinking they've stumbled across a NOS Marelli twin-plug cap for Porsche fitment when in reality they are being sold the Jaguar cap which can be bought 'off the shelf' fairly readily for under $200.
Here is a typically misleading ebay ad for a Jaguar Marelli cap:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Andy
Early 911S Reg #753
R Gruppe #105
Will the Jag cap work on the Porsche distributor?
Peter Kane
'72 911S Targa
Hello: The Jag cap will not work with the Porsche Marelli distributor. It uses a different rotor that will not fit the Porsche distributor. The Marelli cap that fits will also fit a Ferrari and a Lambrogeni (bad spelling I know) Muira I think. Someone is making a Porsche repro Marelli using the Jag cap and rotor. You can find the Jag tune up kits with plugs,cap,rotor and wires for about $180 on e-bay sometimes. Please pass this info along to stop the misinformation. Thanks Eric
Thanks guys....live and learn I guess. This one hurts a little though.
Aaron.
Talk to Supertec...they are making adapter rotors to work with Jag V12 caps.
scott kinder
kindersport@gmail.com
Registry #614
Supertec does have a rotor that will allow the Jaguar cap to fit a Porsche Marelli dist. It is a stellar piece of art work made by BurnBros by a very expensive injection process.
It is in fact a better design than the original and they are very affordable.
BE AWARE that not all Jaguar caps are made by Marelli. Some like some sold on Ebay are made in England by a company called Intermotors and that cap is a dismal piece of ****. You can buy that cap from Kragen for around $90.
Henry Schmidt
SUPERTEC PERFORMANCE
445 Golden Road
Fallbrook, Ca. 92028
Ph: 760-728-3062
Fax: 760-728-3063
Email: supertec1@earthlink.net
Web: supertecperformance.com
Henry.....the cap I got is a Marelli but the owner doesn't want to use it because it's not the correct type for his RSR.
The guys I got it from aren't willing to give my money back......so what's this thing worth?
Still living......still learning......
