Thread: Silver or Gold Paint 1970 -1973
    Does anyone have an original paint Silver or Gold 911 years 1970 -1973 that the two stage paint has not broken down from age etc.? It seems the paint and specificaly the clear coat used in those years where not very well perfected.The paint on my original Silver car suffers from the clear coat disintegrating. In thinking back I can't remember seeing a Porsche in one of these colors that this has not happened to. All the paint in the jambs,compartments, even under the rear license plate is mint and in great condition. Comment's please chime in.
    I've owned one, and seen two or three early cars with original silver paint over the years and they all suffered from "crazing. The 800 mile garage car down at German Autofest however, had held up pretty well, with the exception of some discoloration. It looks to me like it's UV that does in the old syle paint.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    The factory finishes for metallic colors (and metallics only) were in fact a base/clear finish in those days. See the note from the 1970 manual, bottom of page B104 in this thread -
    http://www.early911sregistry.org/for...ead.php?t=5020
    The silvers were the worst for these kinds of problems, as they have the highest metallic content, with gold close behind.
    John Gray
    70 old air
    86 middle air
    95 new air
    In those days the two part paint process would likely have been a metallic base coat of acrylic lacquer with a clear acrylic lacquer applied on top. I don't believe any catalyst was used to harden these paints. That would account for the lack of durability over time. The clear coat was probably applied wet on wet to help the layers adhere better, although clear acrylic lacquers never adhered well to base coats, and thus the peeling and cracking over time. I think this was because the clear acrylic lacked pigment which may have helped the paint "bind" to whatever it was applied over. The clear acrylic became brittle and over the long haul probably dried at a different rate than the pigmented coat. Incidentally, the way you make a crazed or crackle paint finish is to layer a paint over another which dries at a much different rate than the coat below. The top finish will drie with a crackle or crazed surface just like you see on some of these old paint jobs.
    The solid colors I understand were enamels that were factory baked. That made a very durable finish. In many areas of the original paint on my burgundy E the finish looks like it is only a few years old, and this car spent most of it's life in the Arizona sun.
    Scott
    Scott Marshall
    911 S Registry member#724
    1981 Porsche 911SC
    1993 Porsche 968 Clubsport
    1961 Abarth Record Monza, 1964 Abarth Simca 2000
    1962 Abarth 1000GT, 1964 Abarth 850TC Nurburgring
    Quote Originally Posted by aporsche48
    This is a 1973T with 3,900 miles on it, all original silver paint. Car was put inside in 1974, and not brought out until 2004.
    S Registry #265
    R Gruppe #224
    Eade
    Keep it inside before the UV rays get it!
    Dennis Molnar
  1. 65 glove box emblem ; silver or gold ?
    By RS-GT in forum General Info
    Last Post: 05-26-2019, 06:41 AM
  2. WTB: 911T OEM emblem and PORSCHE letters in gold or silver
    By emnemn in forum For Sale: 911 Parts
    Last Post: 08-13-2013, 06:09 PM
  3. Gold vs. Silver vs. Black? 1969 911S?
    By Minkoff in forum General Info
    Last Post: 03-09-2013, 07:32 AM
  4. Oil cap anodizing on '65/'66: gold or silver?
    By kenikh in forum Technical Info
    Last Post: 10-10-2012, 09:47 AM
