Hey all,
I've got a bunch of engine parts that are in need of a good home. I figured I'd post them here before putting them on ebay. Let's start with some NOS stuff
NOS 930 rockers - SOLD!
NOS 3.0 CIS Injector lines - SOLD!
NOS Carrera Oil Pump
NOS Behr Oil Cooler
NOS 3-pin CDI unit
NOS Bosch 2.4S Distributor
NOS Clutch Disk, Aluminum Pressure Plate, and TO Bearing
NOS Clutch Disk, and Iron Pressure Plate
NOS Single Nicasil 2.7 piston and cylinder
NOS 915 gearset
NOS 901 tranny parts
I can provide the relevant part numbers if anybody's interested. I've got a lot more NOS parts, engine-related and otherwise, and will get around to posting them soon.
Now for some, hopefully more affordable, used parts...
Engine:
non-counterweighted 2.0/2.2 crank with rods, still std! $395
counterweighted 2.4/2.7 crank with rods, still std! $395
901.103.101.0R early 2.0/2.2 rods, $25 each
2.4S/2.7S Camshafts, part number 911.105.142.0R and 911.105.143.0R $295/pr
5R 2.4T case in good shape $295
3.2 Carrera Oil Pump $350
Early Heat exchangers, $350/pr
Banana Mufflers $150
complete set of 2.7L 8.5:1 pistons - $120
2.7 Nicasil liners in good shape - $40 each
11-blade fan, alternator, housing assembly - $325
single 11-blade fan $150
Behr Oil-coolers $150 each
2.4T distributor $125
1967 2.0 intake manifolds, $100/pr
Air Filter Housing assemblies $95
Resurfaced flywheels $95
2.4T Camshafts (useful as cores if you're regrinding your cams) $95/pr
2.4T 46/40mm heads $45 each
Fan Shrouds, both green and white, $45 each
Layshafts, all in good shape, crank size "0", $45 each
2.4 Oil Pumps $45 each
Also got a bunch of cam towers, valve covers, non-hydro tensioners and much much more, just ask!
Tranny:
1972 915 core in need of rebuild, mostly disassembled & comes with extra parts $700
1992 964 Carrera 2 G50, 40k mi, with clutch, pressure plate, and axles $2475
911 starters $150
And just to make sure I've still got your attention, I've got complete Euro 964, 993, and 993TT 3.6 engines for sale if anybody's interested...
