Thread: Oil Leaks?
    Oil Leaks?
    It would seem that oil leaks on a 911 are not uncommon depending on the age of the car or engine. To what degree can one expect oil leaks from a thoroughly rebuilt 911S engine with only a couple of thousand miles on it. I would not have thought it unreasonable to expect no leaks for quite some time.
    Any comments?
    Thanks for the feedback.
    A.T.
    Early 911S Registry Member #500
    That is not an unreasonable expectation, but of course it all depends on the "reubild" you had done. I have a 1971 2.2 with about 40,000 on my reubilt engine and I leak one drop a week at most. So I would say if it is a fresh rebuild and it leaks enough to see a puddle after a few days, than the rebuild sucks.
    It should have no leaks for some time, however I have seen the situation where many reconditioned parts are used and resurfaced and so on, and the leaking may start right away from a proplem with an original part that was surfaced, reconditioned or whatever. Identify it and fix it and then you should be OK. I have had breather covers leak when I though the surface was good when resurfaced and I have had return tubes leak because of the corrosion around the crankcase tube hole. In both cases I was forced to use sealer, normally these areas only call for a gasket or an O ring. Once I fixed these issues no more leakes years later.
    Thanks guys. Leaks are beeing addressed. So far nothing serious. Should know more next week. Definitely not a British bike situation...yet.
    A.T.
  1. OIl pressure sender leaks, PN 901.741.551.01
    By caproader in forum Technical Info
    Last Post: 04-12-2009, 03:22 PM
  2. Oil Leaks
    By Gavin English in forum General Info
    Last Post: 05-12-2005, 04:19 PM
  3. Oil leaks at pulley area
    By zaza in forum Technical Info
    Last Post: 12-17-2004, 03:48 PM
  4. Oil Leaks
    By philip guiral in forum Technical Info
    Last Post: 04-12-2004, 08:01 PM
  5. engine leaks...
    By joelrkaplan in forum Technical Info
    Last Post: 10-30-2003, 09:12 AM
