First I would like to wish everybody a great Porsche 2006!
Does anybody know of these valve stem holders:
were standard equipment or optional or aftermarket?
I rarely see them on early 911/912's
Thanks and regards,
Semjon
Thanks and regards,
Semjon
All 3 of my steel wheeled cars had them standard. Their purpose? To prevent the tube from rotating inside the tire..at least that's what a dealership mechanic told me "back in the day". You see, once upon a time, there was a device known as an "inner tube"....
Ok, great! Thank you very much for your quick answer!
Long, long ago when they made ships out of wood or is that too far backYou see, once upon a time, there was a device known as an "inner tube"....
When my older brother took delivery of his Irish Green '65 911 those "stem wires" were in place. The car was shod with Firestone Phoenix tires but I never knew if the wires were to keep the tubes from rotating or just retain the valve stems from the centrifugal forces exerted at higher speeds...Originally Posted by Semjon
Stefan Josef Koch
RGruppe #194/SRegistry #1063
2015 Porsche Cayman S
Yessir,.....thats the real reason for those supports. At very high rotational speeds, the neck of the valve stem get bent outward toward the rim and can crack the rubber or pull the stem loose from the wheel enough to make it lose air pressure. Needless to say, this would have disastrous results.Originally Posted by Bummler
Porsche began doing the same things with valve stem supports on the '76 Turbo's.
Steve Weiner
Rennsport Systems
Portland Oregon
503.244.0990
AHA! I thought so.Originally Posted by Steve@Rennsport
As I recollect those Firestones were tubeless...
Stefan Josef Koch
Hmmm, the "high speeds" of early 911's and 912's? My 912's topped out at 115 or so, the '70T at 125 or so. But, the centrifugal force theory makes sense as well. BTW, as delivered, all 4 of my Porsches ran tubes. '66 912, '69 912, '70 911T, and my current car, '72S. But no stem supports for the fuchs of the S, the fastest one of the 4.
LOL,.....Agreed,....those cars (except the "S") were not considered fast, even in those days.
I did not see these until the 155+ MPH Turbo Carrera was released when a Porsche factory person told me that they were required at that speed.
As the rubber valve stem ages and hardens up with heat, I'd imagine that the speed at which they can leak goes down.
Steve Weiner
Rennsport Systems
Portland Oregon
503.244.0990
Great information guys! Thank you very much!
And Paul is never. However, I am positive that the little wire bits were created to hold the Schreader valve stem in place. Some early steel wheel cars had tubless tire options.
As I recall this. Shawn.
67 coupe roller
99 M96 2.5 litre
early911s reg 447
R Gruppe 399
