Thread: Swinging tacho
    Junior Member
    Aug 2005
    Swinging tacho
    After accelerating, tacho oscillates +/- 1000 rpm and steadies down after 2 - 3 seconds to a stable value. No other issues. Is this normal?, I haven't checked anything yet, pending replies.
    Garrett
    '73 2.4S Targa
    Hi Garrett,
    That isn't normal. If you know your gear ratios, and you know that your speedomoter is accurate, you might check to see whether it is still accurate and just bouncy, or if it needs a rebuild.
    Tacho bounce could also be due to having a non compatible CD Box. For instance, switching out the original Bosch unit for an aftermarket unit like Permatine or MSD could cause the tacho to bounce or not work at all. You might also check the ground.
    Things like oil temp, speedo and revs are important, so if it were me I would ship it off to N. Hollywood Speedometer and have it checked and rebuilt. I have had all of my gauges checked and rebuilt - except the clock whivh runs slow by about 3 hours aper day. I don't even pay attention to it as long as it lights up at night and looks good...
    Huh. I always thought this was normal. I guess I'll have to add this to my project list.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Garrett,
    Also check the purple wire connection (tach) on the side of the distributor... making sure both sides of the spade connector is clean and the connection is tight.
    Cheers,
    Deoxit
    If it is a connection issue, this stuff is seriously good on 'something funny is happening' issues with thirty-five year old electrical connections -
    "DeoxIT is a fast-acting deoxidizing solution that cleans, preserves, lubricates and improves conductivity on metal connectors and contacts. Use as a general treatment for connectors, contacts and other metal surfaces.
    Has a fast acting cleaner to dissolve oxidation and corrosion.
    Physical and chemical changes in the surface condition of electrical or electronic connectors are primary causes of degraded performance of components and equipment. When contact surfaces are exposed to dust, smoke, soot, and other solids suspended in the atmosphere, non-metallic films can form, inhibiting conductivity. Oxidation is the most common reaction that causes metal oxide formation. Salt laden air in coastal areas corrodes metals, forming chloride films.
    While household users of electrical and electronic equipment may be able to cope with such problems for short periods of time, one can realize the critical nature of even minor trouble in industrial, high tech or aerospace applications. Some film deposits are effectively removed with "wash-type" cleaners such as DustALL, CaiKleen, Tuner Cleaners, CAEON 27, CAEON 28 or alcohol. Oxides and sulfides, however, become an integral part of the contact surface and cannot be removed by ordinary contact cleaners. The most effective method of removing these films is chemical action.
    DeoxIT dissolves oxides and sulfides that form on metal contact surfaces, removing these sources of resistance. This restores the contact's integrity and leaves a thin (organic) layer that coats and protects the metals. Special additives prevent the dissolved oxides from reattaching, keeping them in suspension and allowing them to be easily dispersed by the mechanical action of the contact.
    DeoxIT's unique properties allow it to work on stationary and moving contacts and connectors with similar or dissimilar metals. Even when a treated connector mates with an untreated one, DeoxIT will migrate and coat the other. When connectors are separated, DeoxIT will re-coat the exposed metal surfaces.
    DeoxIT's advanced formula contains deoxidizers, preservatives, conductivity enhancers, arcing and RFI inhibitors and anti-tarnishing compounds that significantly increase the performance and reliability of electrical components and equipment.
    CAIG Laboratories has been manufacturing performance chemicals and accessories since 1956. Companies worldwide rely on CAIG products for manufacturing, maintenance and service."
    John Gray
    70 old air
    86 middle air
    95 new air
    Junior Member
    Aug 2005
    Thanks, guys.
    I have checked out the connections, that purple striped lead was quite loose at the spade connection: fixed. Its piggybacked onto a black lead, is this right?
    I have also cheched points gap, I await getting a DVM for next weekend to check out electrics more thoroughly. Then on to instruments if necessary.
    I'll be back
  1. 10K tacho
    By one-two in forum For Sale: 911 Parts
    Last Post: 09-02-2012, 10:46 AM
  2. 10,000 rpm Tacho
    By mrg3.6 in forum General Info
    Last Post: 05-07-2008, 01:01 PM
  3. Replies: 0
    Last Post: 12-29-2006, 04:28 PM
  4. 911 R tacho
    By ydderf911 in forum Technical Info
    Last Post: 11-28-2006, 07:25 AM
  5. Swinging the rear
    By Intheshop in forum General Info
    Last Post: 04-07-2006, 12:51 PM
