Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Fuse Block Replacement
    Apr 2003
    Portland, OR
    Gee, you go do a little project on your car and, like clockwork, you end up with two more....
    I was installing relays for my headlamps and in the process of attaching wires to my fuse block, I broke the block. I ordered a replacement block from Parts Heaven (great service-BTW).
    My question-There are two (sheet metal?) screws holding the fuse block to the car. I am concerned that I will need to remove a subassembly (like what we have for the CDI Box in the engine compartment) to get the fuse block replaced. Is there a removable nut behind the screw holding it to the car or are the screws attached to the body of the car and I can remove just the fuse block? Looking at the PET it appears that I may have sheet metal screws that go into speed nuts attached to the car body. I wanted to verify this before I "dove in".
    TIA
    Harry
    Member #789
    2009 MB C300
    Harry,
    Let me know if you have a problem getting the fuse block. I have a perfect unit. $60.
    Bobby Smith
    Member #299
    porsche911dude@aol.com
    Apr 2003
    Portland, OR
    Bobby,
    Thanks for the offer but I already have one.
    Harry
    Member #789
    2009 MB C300
    What happened? Which relay did you use: the Marcus Sucro generic relay or the Bosch based Daniel Stern relays? I just bought the Sucro relay (cheaper) and want to make sure I don't repeat your mistakes.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Apr 2003
    Portland, OR
    Kenikh,
    I used Bosch relays from Daniel Stern. FWIW, this kit also included 20 amp inline fuses and fuse holders, the crimp connectors you need, and a very nice replacement sockets for the headlamps. While overkill, I used 12 ga wire for the new runs to the headlamps.
    My "mistake" was, when I was attaching a wire from the #1 fuse position to the coil side of the relay, to press too hard on the screw in the fuse block to cause the corner to crack off. Just be gentle.
    Harry
    Member #789
    2009 MB C300
    Super cool; I will end up going with Stern relays later, as I am installing Cibies and driving lights as well. I'll probably use the Sucro unit for the driving lights and the Stern units for the Cibies and 100/130 H4s. Thanks for the advice.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Apr 2003
    Portland, OR
    Kenik,
    I am not sure but if your car is like mine, you have separate fuses for both each headlamp hi beam and low beam. These circuits are used for the coil side of your relays. Since you have one relay for high beams and one for low beams, you will end up with an extra spot for both types of lighting to control something else that can be activated the same time as your high or low beams.
    Harry
    Member #789
    2009 MB C300
    Interesting. I need to research this more.
    The plan is to get the driving lights and Cibies to engage on high beam/flasher and have the under bumper fogs (not yet purchased) on the stock dash mounted switch. I was thinking it would be extremely cool to engage the under bumper fogs when hitting the high beams, as well. I wonder if you can run these lights on two separate circuits...
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Apr 2003
    Portland, OR
    Quote Originally Posted by kenikh
    Kenik,
    FYI: In my car (a 1973) Fuses 1 and 2 are for the high beams, Fuses 3 and 4 are for the Low beams and Fuse 8 is for the Fogs.
    I used Fuse #1 to operate the coil on my hi beam relay, and Fuse #3 to operate the coil on my low beam relay.
    You could use Fuse #2 to activate another relay that will operate the driving lights and Cibies. If it was me, I would put a dash mounted switch in the coil side circuit on and off to control these lamps.
    For your fogs, I would use Fuse #8 to power yet another relay coil to operate the fogs. Again, I would run the power for the fog relay coil through a dashboard switch to allow me to control when it is on.
    Here's a way to wire it all.
    Harry
    Member #789
    2009 MB C300
    This is very, very useful. Thanks!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. FS: rear 3 fuse block
    By dporsche74 in forum For Sale: 911 Parts
    Last Post: 05-03-2013, 06:54 AM
  2. WTB: Engine Bay 3 Fuse Block
    By ESully in forum For Sale: 911 Parts
    Last Post: 04-30-2013, 02:45 AM
  3. FS-nice fuse block
    Last Post: 07-01-2012, 05:42 PM
  4. WTB: 3 fuse block
    By bobmagyar in forum For Sale: 911 Parts
    Last Post: 02-12-2011, 02:14 AM
  5. FS NOS fuse block 10 pole
    Last Post: 08-17-2009, 02:33 PM
