Results 1 to 10 of 19
Thread: 65 911 wood dash
    65 911 wood dash
    Anyone have any good pics of a 65 wood dash. Mine is, ahem, not so nice so I'm going to try to either restore it or probably make a new one. Problem is I don't know exactly what wood to use or the proper color to stain it.
    I have seen some with a somewhat reddish hue which I am not too fond of. If possible I'd like to go blonde or medium. Of course stock would be best. Guess thats why I'm asking. Any help?
    Tom
    Tom,
    See below. I agree with you that there is a great deal of variation in color. If you are restoring an original the usual deal is to re-veneer the dash in a color and grain close to the original. It's not a solid block of teak that can be profiled like the deck of a boat, in fact, if you look around the edges of your radio hole, you can see the plywood backing, and the actual veneer, which is about 1/8" thick.
    Good luck! Let me know if you find a good resource for veneering, this is a few items down my list.
    http://forums.pelicanparts.com/showt...highlight=wood
    tom,
    that wooden dash looks like mahogany.
    it is a red wood and will always darken with time.
    if you want blonde, teak is a good choice.
    supplies here: http://www.woodcraft.com
    search veneer (duh)
    ps, did you decide on the doortops?
    bob
    bob moglia
    '72 E sunroof coupe
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    Here's a photo Tom.
    RGruppe #183
    Apr 2004
    What are those lights between the switches above the radio ? I've never seen those before.
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    Those lights are an oversteer gauge. When they point in the direction the car is traveling it is time to add some opposite lock.
    But seriously Jens, what do they tell you?
    Shifter console on this car is not correct. The shifter knob should be black plastic, not the aftermarket "barrel" shaped wood knob on there, the shaft should be chrome (not black), and the shifter boot should be rubber, not vinyl.
    I am guessing that those lights are some kind of early warning lights before Porsche added to the combo gauge faces.
    Anyone know for sure? The interior wood looks nice though...
    Also, what is the lever in the top of the tunnel in front of the shifter?
    Aug 2003
    vahmont
    Wink
    I just popped the photo up as a representation of the factory wood finish (faux teak?). I'm pretty sure the indicator lights are added after the factory and are likely an early version of a tire pressure warning system ( ). Nicely placed.
    RGruppe #183
    Gruen,,, I dont see anything wrong with the shifter boot... It should be leather on very early cars.
    Robert..
  1. Wood trim on dash
    By john wurner in forum General Info
    Last Post: 11-09-2012, 03:25 PM
  2. 66 wood dash pin clips
    By oscillon in forum Technical Info
    Last Post: 12-14-2010, 12:09 PM
  3. WTB Wood Dash for 65 66
    By jaldeguer in forum For Sale: 911 Parts
    Last Post: 09-23-2009, 05:32 AM
  4. FS wood dash
    By jennetd in forum For Sale: 911 Parts
    Last Post: 04-30-2009, 09:49 AM
