Thread: re-keying door handle locks
    Does anyone know where I can purchase a kit that allows me to re-key a door lock that doesn't match the driver door lock. iIunderstand there are/were kits available that have a number of different sized pins that allow you to change out with the existing pins in order to match the profile of your key.
    Scott
    Scott Marshall
    911 S Registry member#724
    1981 Porsche 911SC
    1993 Porsche 968 Clubsport
    1961 Abarth Record Monza, 1964 Abarth Simca 2000
    1962 Abarth 1000GT, 1964 Abarth 850TC Nurburgring
    FWIW - I had my door tumbler redone for something cheap - $10 ea? Dropped them off during lunch hour and picked them up before heading back to work.
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Apr 2003
    Portland, OR
    I never had any luck finding the wafers you need to re-key properly. I had my locksmith do mine for $15-20/lock.
    An alternative some say they have done is to pull the lock cylinders and put your key in the lock. You can then grind off the part of the wafer that sticks out and the lock will work. YMMV.
    Harry
    Member #789
    2009 MB C300
    Do it yourself, it is very easy and does not take long, plus you can find out how it all works. After years the tumblers need a good clean anyway. The springs which push out each pin get clogged up. I re-keyed both my door locks today to fit a new ignition key and it took 30 mins to re-key both of them. Take the tumbler out and fit the key into the lock, you will see which pin needs flatting back or swapping with other pins. Then simply re-fit.
    HTH
    Alan.UK
    Thanks for the replies. I think I will try to re-fit and grind the old pieces to match the other side.
    Scott
    Scott Marshall
    1981 Porsche 911SC
  1. Door Locks hard to open/close, not now
    By Haasman in forum Technical Info
    Last Post: 09-28-2013, 06:43 PM
  2. FS: 67 door locks
    By John79sc in forum For Sale: 911 Parts
    Last Post: 06-15-2011, 05:44 AM
  3. WANTED: door handle seals for 1969 door handles
    By obrut in forum For Sale: 911 Parts
    Last Post: 05-15-2010, 06:15 PM
