Thread: 1970 2.2S engine s/n 6300653
Threaded View
    This engine was built by Supertec Performance. It is still strapped to the shipping pallet. It has not been installed since the build. The specs are as follows:
    2.2 S Case # 630 0653
    Rebuilt to 2.4 performance specs (200 + HP)
    2.4 S 9.2-9.5 TO 1 compression JE pistons and Mahle cylinders
    70 Std crank
    Install case savers and street head studs
    New main bearings
    New rod bearings
    New inter. shaft bearings
    2.2 Liter oil pump [modified for max flow]
    Turbo pump modification
    New timing chains and ramps
    Turbo chain tensioners with chain savers
    Reconditioned rods w/ new bolts and ARP nuts
    Mag and polished crank
    Factory 911 “S” cams
    Complete engine balance
    Complete valve job w/ manganese-bronze guides
    Stock valve springs and retainers
    36 mm intake ports 35 mm exhaust ports
    Powder coated valve covers and sheet metal
    Turbo valve covers (lower)
    Sonic clean and pressure test cooler
    Rebuilt 55 amp alternator
    Engine wiring for mechanical fuel injection
    2.2 S Mechanical fuel injection
    New plug wires, plugs, cap & rotor
    Rebuilt distributor
    Reconditioned stock exhaust, new muffler
    Stock flywheel
    This engine has the following warranty by Supertec Performance:
    Warranty; 24 month / unlimited miles. Reasonable use beginning at installation.
    $12,500. barenstam@metrocast.net
    Brian
    Early S Reg #797
  1. FS: 1970 S Complete Engine
    By 72targa in forum For Sale: 911 Parts
    Last Post: 01-14-2016, 12:40 PM
  2. FS: 1970 2.2 engine and 901 transmission
    By esses62 in forum For Sale: 911 Parts
    Last Post: 12-18-2013, 06:40 PM
  3. looking for 1970 S engine 6301498
    By timgt3 in forum General Info
    Last Post: 10-02-2012, 12:51 PM
