Thread: oil line update on SWB
    I learned the hard way($$)
    I wanted the added oil cooling of the external lines, so I brought and installed factory spec. lines, since the bodys or the same as the LWB cars everything fit nicly, intell I put my wheels on. Since the trailing arm is shorter on the SWB car, my tire hit the lines as the cam out of the thermastat/P. releif valve. Sooo you can use all the factory lines except the ones that go in the left rear wheel well. Make those. Live and learn, then die and forget it all.
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    once again, nice job Bob, very clean. I had bob's set up, ( not as much shine though) and I was limited to 195 tires which is very tough to get track tires in that size, so I re ran the rear lines up and over and am able now to run the 205's that inable me to get track tires. Sorry should have metioned tire size issue and reason
  1. WTB: main oil line junction, between case and line
    By mcaterino in forum For Sale: 911 Parts
    Last Post: 12-06-2010, 04:47 PM
  2. 71E resto..update XX, it's in there.
    By X-Faktory in forum General Info
    Last Post: 02-17-2010, 09:20 PM
  3. Pan update
    By berettafan in forum Technical Info
    Last Post: 08-13-2007, 04:51 PM
  4. Replies: 24
    Last Post: 06-06-2007, 09:42 PM
  5. 67S Update
    By BBausser in forum General Info
    Last Post: 04-09-2006, 10:23 AM
