Results 1 to 2 of 2
Thread: Neatrix bushing install
    I have a set fo Neatrix bushings that I am installing in my 70S and am concerned about how tight they fit. It seems to me that when you have to cram the bushings into the housings so tight that it would effectivly lock up the suspension. Do I need to clearance them a bit?
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Apr 2003
    Portland, OR
    Cornpanzer,
    When I did mine, I superglued the ID of the bushing to the Springplate and crammed the bushing into the hole. I used extra long bolts to push them in a fraction of an inch at a time to ensure they went in evenly.
    Harry
    Member #789
    2009 MB C300
  1. Looking for swb rear a arm bushing install info
    By Chris Pomares in forum Technical Info
    Last Post: 03-11-2015, 02:35 PM
  2. Elephant Racing front rubber bushing install
    By berettafan in forum Technical Info
    Last Post: 03-23-2010, 11:16 AM
  3. Rear sway plastic bushing install...
    By jcarpio in forum Technical Info
    Last Post: 04-16-2008, 10:37 AM
  4. Replies: 3
    Last Post: 12-18-2007, 07:30 PM
  5. Neatrix spring plate bushings glue?
    By Wolf Knierim in forum Technical Info
    Last Post: 01-13-2004, 11:13 PM
