Results 1 to 1 of 1
Thread: Fs: Sports Information Carrera
    Mar 2004
    Castro Valley, Ca.
    all;
    XEROX COPY of;
    SPORTS INFORMATION CARRERA RACING VERSION
    Fia Regulations Appendix J Group 4
    the cover page reads in part;
    In the following Sport-Information Circular is the Carrera RSR described. We have only included information not pertaining to the normal Carrera RS.
    descriptions of; Racing Engine Carrera RSR, crankcase, crankshaft, connecting rods, pistons and cylinders, cylinder heads, injection system, camshaft, ignition exhaust system, oil container & clutch.
    Technical data of the Competition Engine Carrera RSR (911/72)
    (did you know that there is a different redline depending on whether or not the engine is under load ?)
    Important Torque Values (Engine and Gearbox)
    Chassis (front axel, rear axel, pedal assembly, brake assembly, etc.)
    Transmission oil (eg; only Shell gear oil = 17 47 may be use in transmissions with the limited slip differential)
    complete listing of special gear sets (including part numbers)
    Tortion bars, Chassis settings, etc.
    Shock absorbers, Stabilizors, Brakes, adjustment of brake balance, brake fluid, (important; when bleeding the brakes both the front and the rear systems must be bled at the same time. Right side first and then the left)
    Steel wheel nuts are recommended for racing.
    Wheels and Tires, Spare wheel.
    Sales, guarantee and delivery information;
    etc., etc., etc.
    April 1973
    $25 delivered postpaid to any U.S. address. elsewhere at additional cost.
    thanks for listening.
    cheers
    jerry
  1. Replies: 30
    Last Post: 08-22-2014, 08:33 PM
  2. FS: '92 Carrera RS service information
    By typ901 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 05-04-2013, 08:07 PM
  3. FS: '92 Carrera RS America service information
    Last Post: 03-21-2013, 11:11 AM
  4. Replies: 24
    Last Post: 08-29-2012, 08:22 PM
  5. Sports Information '73 RSR
    By typ901 in forum For Sale: 911 Parts
    Last Post: 03-05-2007, 09:12 AM
