Results 1 to 2 of 2
Thread: Correct way to drain and refill transmission?
    Mar 2005
    What is the correct way to drain and refill the transmission? How many quarts of oil should it take? How do you pump the fluid from the container into the transmission? Can it be done without a lift or a jack? Any tricks that make it easier? Thanks in advance.
    Apr 2003
    Portland, OR
    dhopkins,
    Check out this Web page: http://members.rennlist.com/harryd/Trannyoil-Change.htm.
    Most of your answers are here. To hold the funnel, you can attach it to a step ladder.
    Harry
    Member #789
    2009 MB C300
  1. WTB: 29:21 5th Gear For a 915 Transmission (TL) if I'm Correct
    By 9146insc in forum For Sale: 911 Parts
    Last Post: 03-16-2013, 10:26 AM
  2. Chasing a battery drain
    By Max (SD) in forum Technical Info
    Last Post: 05-15-2012, 09:54 AM
  3. Wtb:drain plugs
    By 71-911T in forum For Sale: 911 Parts
    Last Post: 01-11-2012, 04:25 AM
  4. Battery Drain
    By NV Stig in forum Technical Info
    Last Post: 01-22-2009, 01:39 PM
  5. Sunroof drain location for '68 911
    By fryardds in forum General Info
    Last Post: 11-04-2005, 03:40 PM
