Thread: Rss
    Rss
    I tried to pull an RSS feed from this site, with no luck. Is this feature enabled on the site or not?
    From the site FAQ
    The administrator may have enabled RSS syndication, this allows you to view newly created threads in guest viewable forums without visiting the board.
    The feeds are currently provided in two formats, RSS and RSS v2. The differences are as follows:
    RSS 0.91 - This feed is based on a standard written by netscape and provides a link and the title of the thread.
    http://www.early911sregistry.org/for...l.php?type=rss
    RSS 2.0 - This feed contains title, author, date and the contents of the first post of the thread.
    http://www.early911sregistry.org/for....php?type=rss2
    To add this to MyYahoo click here.
    The forums to which this applies can also be limited to specific guest viewable forums by adding another paramater to the URL containing the forumids as follows:
    http://www.early911sregistry.org/for...2&forumids=123
    If you would like the content to be generated for multiple forums you can seperate the forumids by commas.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Kenikh,
    Please ask your questions to our web master Mike Larson
    webadmin@early911sregistry.org
    Mike should get back to'ya directly...
    Hope this helps,
    Email sent. Thanks!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
