Results 1 to 10 of 19
Thread: Bearing Clearance in Stearing Column?
    I disassembled my steering column today to repack the bearings and I realized that there was a very significant clearance between the shaft and the bearing closest to the steering wheel. Am I missing a part? I will be using a MOMO hub which I don't have yet so I am unsure if there is a part on the back of the MOMO hub or the original wheel that would take up this clearance.
    Thanks in advance.
    Bob
    1970 911S Targa
    On the road again soon.
    Apr 2003
    Portland, OR
    Bob,
    Below is a shot of an assembled early stering column (thanks Shawn French aka thrown_hammer@pelicanparts). Note the large gap between the column and the external assembly.
    To fill that space, there is a spring and small bushing you need to put on the shaft of the momo adapter (or spline on the original steering wheel). A shot of the parts and how they are mounted is below as well (thanks Oliver aka phoenix@pelicanparts).
    Harry
    Member #789
    2009 MB C300
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by HarryD
    Now wait just a darn tootin minute!
    http://www.early911sregistry.org/for...ead.php?t=9795
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Apr 2003
    Portland, OR
    Quote Originally Posted by 70SATMan
    Michael,
    Good catch. I did not notice that the spring and bushing on the spline are reversed. I inserted the correct picture.
    The bushing should be at the end of the spline.
    Harry
    Member #789
    2009 MB C300
    Jul 2003
    Santa Cruz, CA
    I'm gettin the feelin you're just messin with me, huh?
    That wrong picture is how my wheel came out and what I was talking about. Maybe I'll put the wheel back on tonight with the bushing reversed to see if it clears up my wobble.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Apr 2003
    Portland, OR
    Michael,
    I would like to say I was messing with you but, truth be known, a "Senoir moment" is a more apt description.
    However, on install, not to worry, there are only four ways to install the parts. You feeling lucky? (hint: the piciture is correct)
    Harry
    Member #789
    2009 MB C300
    Senior Member larwik's Avatar
    Dec 2003
    Los Angeles, Ca
    Uuuuhhhhh....
    ..So Harry and Michael...the third photo in post #2 above is correct then?...Please don't complicate it too much for me...a simple "yes" or a "no" will do!...and we'll go from there...Thank's / Lars...
    Lars Wikblad...
    Early 911 "S" Registry # 527
    "R" Gruppe # 314
    Thanks Guys,
    Harry, you really had me scratching my head there with the first pic.
    To be honest I still dont really understand the design of this bearing/spring/bushing arrangement. When I get all my parts in one place I will provide a status update.
    1970 911S Targa
    Apr 2003
    Portland, OR
    Quote Originally Posted by bobmagyar
    Thanks Guys,
    The first picture I posted has the metal casting you show installed in the steering column. The part you show is directly behind the horn contact ring. The next shot are the spring and bushing loose. The last shot is the spring and bushing on the steering wheel 9or steering wheel adapter before you istall it on the steering column.
    I note in your picture, you show the 27 mm nut that is used to fasten the steering whell to the shaft. What is the object behind the nut?
    I hope this helps.
    Harry
    Member #789
    2009 MB C300
    Apr 2003
    Portland, OR
    Quote Originally Posted by larwik
    Yes, the third photo is now correct.
    Harry
    Member #789
    2009 MB C300
  1. WTB: 911 Steering column column cover (LWB)
    By RSwannabe in forum For Sale: 911 Parts
    Last Post: 04-22-2013, 07:25 AM
  2. Replies: 3
    Last Post: 02-09-2013, 04:06 PM
  3. SWB Steering column bearing remedies
    By Hayden Burvill in forum Technical Info
    Last Post: 08-12-2009, 04:27 PM
  4. What is this - RSR stearing wheel?
    By parced@telia.co in forum General Info
    Last Post: 03-11-2007, 01:55 PM
  5. Lost on RS stearing wheels
    Last Post: 03-06-2006, 07:33 PM
