Thread: Polishing window frames? 68 frames different?
    I just did a 1" test section on my window frame using 400, 600, 1000, 1500, 2000 grit sand paper and was impressed with the mirror like results - no more fine scratches. BUT I noticed that the frame must have some sort of clear coat protection because the outer areas got "foggy" unlike the area I sanded through - flashbacks from when I stripped one fuch. AND I was concerned about sanding through any chrome plating to raw metal. HOWEVER I do recall a few people telling me the 68 door frames are lighter due to the material. SO can someone shed some light in the subject for me?
    Is the 68 door frame different from other model years? If I started with a rougher grade to wipe out some of the deeper scratches do I run the risk of going through any plating? I assume that much like polished fuchs a little bit more care will now be involved without the clearcoat. This might be thge excuse I need to scotch brite all the brightwork on the car .
    _B
    Sent from a pay phone
    888888 eL, Oph'eL'ia
    Instagram: werk_crew
    www.werkcrew.com
    www.werkcrew.tumblr.com
    www.handofwinter.tumblr.com
    Bob,
    68 was the first year of aluminum. You are removing the anodizing. These are a tough part about these cars. I would love to know someone who can redo these frames as original.
    Don
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    Ray Crawford had his done at Anobrite www.anobrite.com. He says that they are better than new. I'm sure many of you have seen them in person (I have not).
    -Scott
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    The Netherlands
    window frames
    It seems that the link to anobrite doesn't work....
    Anybody knows if there is a company in Europe that can do (anodize) the window frames and get them back in their original state?
    Thx,
    Cees
    I think I am just going to polish mine and not worry about anodizing them. They should be fine without the anodized clearcoat - yeah?
    _B
    www.werkcrew.com
    May 2003
    Eugene, Oregon
    I corrected the link above. It now works.
    Bob-
    The anodizing process prevents corrosion, so the trim is more vulnerable without it. It will likely require re-polishing on a regular basis. I understand the temptation, as my door window frames are trashed, but I'm going to hold out for an eventual ano-brite job.
    -Scott
    ’15 VW GTI
    '70 911E, Sold
  1. WTB - Nice Door Frames Quarter window frames/trim
    By warren356 in forum For Sale: 911 Parts
    Last Post: 12-19-2012, 05:03 AM
  2. LWB Window Frames
    By Bert in forum For Sale: 911 Parts
    Last Post: 09-20-2011, 11:44 AM
  3. Replies: 4
    Last Post: 08-16-2011, 11:24 AM
  4. FS AL Window Frames
    By gnus911 in forum For Sale: 911 Parts
    Last Post: 03-27-2011, 01:16 PM
  5. FS: 911/912 Window Frames 69-73 LWB
    By rennmark71 in forum For Sale: 911 Parts
    Last Post: 12-09-2010, 04:49 PM
